Led Electrical Mystery?
madmax
Current bike(s): 2 x ZG1200 B3 & B7
1 x ZG1000 - GTR1000
1 x ZG1400 - GTR1400
Post by madmax »
Hi every one, I have a strange electrical mystery while I was changing my rear stop/tail lights to LED’s. My bike has 4 bulbs/lamps at the rear . Two in the trunk & two below the licence plate at the bottom.
All these Led bulbs are P21/5W - Led 1157- Bay15d Bulbs. A direct replacement for the standard bulbs. I’ve tested each led across a battery & all are OK.
Now this is where it gets interesting. With standard bulbs everything works OK.
If I change only the bulbs in the trunk to leds, then the leds don’t work. If I remove the lower bulbs, then the trunk leds work. If I mix any combination of leds with filament bulbs then problems. Nothing seems to work correctly. With all leds fitted, no problems. Strange!
Now all 4 bulbs are in parallel, with just 3 wires. Earth –ve. side light +ve & stop light +ve. So why does a filament bulb in parallel with a Dual led have this effect.?
I’ve also changed the indicator bulbs to leds. The front are also dual filament type. Not a problem as the side light cable is disconnected at the front on my bike. So I connected it up to see what happens. Sure enough, problems.
Indicator stayed on, when side/ running lights are on??? Fitted standard bulb everything OK.
Here in the UK you can’t have amber lights on the front of your bike ‘On’.
Amber lights should be indicators only.
Now that I’ve fitted Leds all around the bike, every thing is working fine.
So the question is why does having a filament bulb in parallel with a led cause this problem.? It may be the fact that they are dual Led bulbs.
I have tried two different makes with the same outcome.
It will be interesting to see your comments.. Just to let you know I’ve been into electronics for 50 years & I cannot figure this one out ?
Has liked: 228 times
Been liked: 602 times
Re: Led Electrical Mystery?
This might not have been addressed here because few XII have the "GoldWing" fender lights. I understand that Honda sued MaKa over it, and so since an early model year XII painted over the fender lens and abandoned it. I removed that paint, inserted 1157 sockets into the housing (which is still there), and started using those lights as part of getting rid of my trunk.
I also encountered issues, complicated by not being able to find reliable sockets. I wired these from scratch, working from the elec plug that used to go to the trunk. (I added a fender taillight at the same time, so no big deal.) In other words, I couldn't figure it out either.
I'm suggesting starting over wiring these fender lights from sources under the trunk. I bet that'll be easier than trying to sort the existing harness, which obviously wasn't designed with LEDs in mind.
But I'm waiting for Dave to chime in, using his swell circuit-chaser app (that I'm very jealous of).
Has liked: 105 times
Been liked: 273 times
Hello Nails, madmax;
sorry Nails but my circuit chaser app is only a coloured schematic from a supplement, a ruler and pen and paper. No electronic wizardry here.
Max I am wondering if the imbalance in resistances could be a factor even though the filament and the LED are wired in parallel and in theory it shouldn't matter. Perhaps the filament is stealing all the available power, just a guess here.
The main thing is you have all systems working as they should, but that is a real puzzler of an occurrence.
Good talking with you
Been liked: 104 times
LED’s need proper continuity negative and positive wired correctly. Filament bulbs do not. I have found on mine that the rear end lights where not wired correctly from the factory. I reversed the wires and everything worked correctly. Check continuity in each socket.
The only thing worse than being jealous of something is being jealous of something that doesn't exist. :thk:
Barry (Wed Sep 30, 2020 4:47 am)
madmax
Post by madmax »
Hi, thanks for your comments, My bike didn’t have a rear fender light when I bought it. But one became available on eBay so I got it and fitted it. The wiring just connects to the spare connector behind the seat, next to the trunk connector. These are just connected together in parallel.
In theory there shouldn’t be a problem.
I’ve checked all earths to black / yellow wire & are OK. Even between lamp holders every thing is OK. I used my Fluke 87 on the connector behind the rear seat to measure the voltages. Again no problems.
If there was a reversed connection then the led wouldn’t work, but they do, so I can count that out as a problem. Like I said before if all are Leds then no problem.
So the connectors & lamp holders must be OK.
Change to filament & every thing OK, but mixing them is a no go. I have spent hours trying to figure this out. The leds I used for the indicators are a different make & style but the same problem when the other half of the Led on the front indicators are connected. ie. When the running lights are on, then problems.
I’ve checked each LED & they work OK. I’ve used a battery & a power supply to see if there was any difference. The leds work fine. +12volt to either or both connectors & - ve to the case. They work great. Strange.
I hate having a problem I can’t explain. I’ve now given up trying to figure it out.
Leds fitted & everything works OK. This is going to niggle me for ages
madmax wrote: Thu May 21, 2020 6:56 pm I hate having a problem I can’t explain. I’ve now given up trying to figure it out.
Well, I do hope you get over it. I did. :lol:
Now wire in one of those flashing units -- brakes flash four times before staying on -- and you'll be welcomed right through the Pearly Gates.
"Now wire in one of those flashing units -- brakes flash four times before staying on -- and you'll be welcomed right through the Pearly Gates."-Nails.
I bought some of those and they definitely grab the attention of those following behind me. Pretty neat plug and play install. I have them in the top trunk and lower fender lights. I figured I needed the flashing brake lights as I have 14 separate Red tail light bulbs on the back.
I know I know, that sounds like a lot but 10 of those are the wee little T-10 bulbs in the Markland saddlebag/trunk top rails and rear mudguard light assemblies. I saw a post awhile back about installing T-10s into the unlit reflector portion of the rear turn signal housing so those got added as well. That was a simple mod using a short portion of a 3/4" barbed plastic hose connector epoxied on top of a 1/2" hole drilled into the unlit portion. Then I used a pigtail from the front marker lights and it fits snugly into the bore of the pipe connector-voila, an extra 2 rear facing T-10 bulbs.
I made a mistake when I installed my first illuminated mudflap, for some brain dead unknown reason I wired it into the saddlebag side marker harness. What a pain in the %s@ that was every time I wanted to remove the saddlebag or the rear fender portion! I had to remove the signal light and disconnect the bullet connectors. Finally I clued into my mistake and wired it into the lower fender light harness behind the lower fender tail/brake light assembly--much better.
Anyway, I gotta go and rescue some work hardened rubber carburetor ducts from a softening experiment as it is almost the 12 hour immersion time.
Later,
Has liked: 481 times
Been liked: 435 times
I bought flashing LED 1157 bulbs from Amazon. What's really cool is they flash in different patterns every time I hit the brakes. Sometimes all at the same time, sometimes like wig-wags, sometimes the trunk lights wig-wag and the fender light doesn't, sometimes the other way around. Really neat.
https://smile.amazon.com/gp/product/B07 ... UTF8&psc=1
GrandpaDenny wrote: Fri May 22, 2020 4:43 pmI bought flashing LED 1157 bulbs from Amazon.
I bought similar bulbs from SuperBrightLEDs, but they quit selling them. Thanks for the alternate source.
So I don't really have a flashing unit, just the smart flashing bulbs. I only use one (bright) taillight because the taillights in the fender quit working again. But when I hit the brakes that single taillight flashes and the fender lights fire up (also bright LEDs).
Has anyone found an aftermarket 1157 socket that actually works? It needs to be short out the back -- limited clearance in the fender housing.
KPAX
4
Current bike(s): 2003 Kawasaki Voyager xii
2018 Suzuki GSX-S1000F
Been liked: 10 times
Post by KPAX »
Nails wrote: Thu May 21, 2020 2:14 pm This might not have been addressed here because few XII have the "GoldWing" fender lights. I understand that Honda sued MaKa over it, and so since an early model year XII painted over the fender lens and abandoned it. I removed that paint, inserted 1157 sockets into the housing (which is still there), and started using those lights as part of getting rid of my trunk.
Nails, how did you remove the paint? Once removed is it a standard red lense?
KPAX wrote: Tue Sep 29, 2020 4:30 pmNails, how did you remove the paint? Once removed is it a standard red lense?
I used a wire wheel on a Dremel -- nothing complicated. It's pretty butchered on the inside. I put a couple bright red LEDs in there, and it looks fine on the bike.
What's not so fine is the 1357 sockets. I can't find ones that actually work -- seems they're all crap. Right now, I think only the tail lights are working (the sockets are very touchy). They also have to be short to fit in there.
Has liked: 100 times
Been liked: 69 times
Post by Barry »
I soaked mine in goof off over 24 hours, then used a scrub brush. Had to do that 2 or 3 times. Some people claim that brake fluid will do it. When I tried that, it caused the surface to be chalky which then required polishing. Surf around. Lots of ideas on how to do this.
KPAX
4
Post by KPAX »
Ok, thanks, Goof Off sounds pretty easy
Barry said brake cleaner, did he mean brake fluid? I ask as I've read many times
be real careful when adding brake fluid if you like the paint under where you are
working, as it sill disappear. This is all - IIRC- and at my age.... we're both in
trouble here!!! GBG ... but I think the fluid is nasty...
Post by Barry »
Cranky,
You're correct. Brake fluid, Dot 3 or 4. I will edit my post.
