Source for stainless brake lines for an '86 XII?
chicagorandy
Has liked: 9 times
Been liked: 14 times
Post by chicagorandy »
I note that Galfer's start with '87 and mine is an '86. Also opinions on keeping the line splitter vs a dual line banjo bolt install?
thanks
Has liked: 100 times
Been liked: 69 times
Re: Source for stainless brake lines for an '86 XII?
Post by Barry »
Contact HMB Don on this site. I'm not aware of any differences between the '86 & newer models when it comes to brakes. Some people have trouble bleeding the front brakes with the factory setup. Perhaps the dual line eliminates this issue. The dual line banjo setup doesn't look nice IMHO.
Been liked: 235 times
Speed Bleeders make it super-easy. They contain a one-way valve: open them, and then fill the reservoir, on top, with fresh brake fluid; pump the lever until you get a steady stream of fresh fluid out the valve, at the calipers.
Otherwise, you can reverse bleed, pumping fluid up, from the calipers, to fill the reservoir. Google it for instructions, and tools. This technique pushes the air bubbles up the line, which is the way they naturally want to go -- you will not be attempting to force the air bubbles to move downwards, as is typical (Speed Bleeders have worked for me, but I see the advantages to reverse bleeding). Cheers!
:thmup:
chicagorandy (Thu Aug 13, 2020 2:37 pm)
chicagorandy
Has liked: 9 times
Thanks,
I actually have a bunch of Speed Bleeders, just have not gotten around to installing them. HMB Don's set for brakes and clutch are still available at $210, so I'll have to save up for a set.
Has liked: 852 times
When you are ready to start bleeding the system Make Sure You Cover The Fairing with a brake fluid resistant cover! :thmup:
The fairing hates brake fluid :wnk2: and you will probably spill some.
One of the members showed the ugly results some time back :cry2:
chicagorandy (Sat Aug 15, 2020 1:25 am)
Post by Barry »
Randy, The Galfer's lines from Don are worth every penny. Major improvement.
These users liked Barry's post:
cushman eagle (Sat Aug 15, 2020 1:13 am) • chicagorandy (Sat Aug 15, 2020 1:25 am)
Barry wrote: Fri Aug 14, 2020 1:40 am Randy, The Galfer's lines from Don are worth every penny. Major improvement.
I put the stainless lines on a couple years ago,and noticed a huge improvement in the brake feel! :thmup:
Been liked: 134 times
I agree, "The Galfer's lines from Don are worth every penny. Major improvement." And they LOOK so much nicer :-D
chicagorandy (Sat Aug 15, 2020 10:30 am) • Barry (Sun Aug 16, 2020 8:19 pm)
