Has anyone installed a gas shutoff valve?
- Current bike(s): 2002 kawasaki voyager xii
- Has liked: 9 times
I was wondering if anyone has installed a gas shut off valve. It seems when my voyager sits a few days it drips gas ever so slightly. I suppose the needle valves aren’t sealing perfectly, nor a bowl gasket too.
- drtechnology
- Has liked: 113 times
- Been liked: 17 times
Re: Has anyone installed a gas shutoff valve?
Yea, sorry mine does not have one and I have no drip, so I would not see the need to install one. I am sure someone else here will know more if they had a similar issue as urs and chime in :)electriccruiser wrote: ↑Thu Jul 23, 2020 2:08 am I was wondering if anyone has installed a gas shut off valve. It seems when my voyager sits a few days it drips gas ever so slightly. I suppose the needle valves aren’t sealing perfectly, nor a bowl gasket too.
- Barry
- Has liked: 100 times
- Been liked: 69 times
You could have bad needle valves or float bowl drain screw rubber O rings.
