WANTED: Saddlebag rail light parts
Has liked: 105 times
Been liked: 273 times
I am trying to complete 2 sets of bag rail lights and a mudflap and I am looking for 3 of the rectangular chrome plated plastic Markland bulb holders and 3 of the chrome plated plastic lens hold down frames. Ideally the hold down frames would not be cracked where the screws go through.
I don't care what condition the red lenses are in, or even if there are no lenses is OK. I don't need any of the metal housings but I do need 2 of the RH and 2 of the LH chrome metal end caps as shown in figure 3, part #s 430610 LH; and 430615 RH. The one shown in figure 3 is the RH end cap.
So if you have some old light parts hanging around looking for a home please let me know.
Thanks,
Been liked: 235 times
Re: WANTED: Saddlebag rail light parts
Can't help with your actual request, but I will chime in with possible alternatives...
I bought some LED marker lights, from Wal-Mart's auto department, several years ago. They were silver, around 12 inches long, with Red LED's. They mounted with foam tape, to the outside of my saddlebags (had to drill a small hole to feed the wires through the bags). I wired them into the running lights, but they could be wired into the turn signals, if desired.
There are many such options available at most auto parts stores. If you have your heart set on what you posted for, I wish you luck. If not, shop around and see what you can find for alternatives. you may be able to adapt something modern to fit your hardware. Cheers!
:wnk2:
Thanks SgtSlag for the suggestions.
I am sure they will be of use to many but I am looking for the actual OEM rail light parts, being the masochist I am for the rare "unobtanium" original parts.
Regards and thanks again,
I finally got around to taking a photo of the actual items I posted about.
