Evening guys. Possibly a dumb sounding question here. I've got an oil leak and believe I have it traced to the oil return tube. Looking at the schematics I use at Bike Bandit it shows a rubber o-ring so I ordered one. I took the bolt out of the return tube and to my surprise there is no o-ring there. So my question would be, which I really hope someone can answer, is which side of the return tube would that o-ring go. Between the tube and the engine, or between the tube and the bolt?
Thanks guys....
Oil leak
- Has liked: 852 times
Re: Oil leak
Hi,chefman84 ,Most of the banjo fittings we see in our repair shop,which it sounds like you are describing,use a copper or aluminum washer on both sides of the line.
I see three applications on the bike bandit site that shows what I think you are describing and the part numbers are 11009,11009A,and 92065 and from what I can tell,they show one on each side of the line on each of the applications.
Let us know what you find out
- Current bike(s): 1998 Kawasaki Voyager XII
Re: Oil leak
Cushman eagle, you are right. I went back and looked closer through the schematics and I do see I was looking at the wrong part. Thanks for the heads up!
