Drive shaft fluid leak question
- woodsm84
- Current bike(s): Dr650
VRSCA 2003
Voyager XII - Has liked: 22 times
Noticed this red fluid leaking onto the exhaust below the left foot peg from the shaft. I just had it fully serviced. Is some leakage to be expected from overfill, or just a service in general?
- misft
2003 Voyager XII - Has liked: 0
- Been liked: 13 times
Re: Drive shaft fluid leak question
Red sounds like it was changed, perhaps overfilled. New front differential oil seal is not particularly expensive or hard to replace.
- Has liked: 852 times
There should be no fluid leaking there.See if you can identify where the fluid is coming from,and where there is red fluid.
If the o-ring between the final drive and the drive shaft is weak,and if the final drive is overfull,that could be the source,if the oil is red.
If the fluid is antifreeze and the coolant bottle behind the left chrome cover is overfull,that could be your source of fluid also,if the coolant is red.
Please keep us posted.
- woodsm84 (Sun Feb 20, 2022 2:37 pm)
- Has liked: 481 times
- Been liked: 435 times
I agree with Misfit - overfilled final drive. Should be filled to 1/4" below the fill plug - if filled all the way (as per the manuals) it will leak like you noticed.
- woodsm84 (Sun Feb 20, 2022 2:38 pm)
South Jersey Retreads
Patriot Guard Riders
Warriors Watch Riders
- Been liked: 104 times
Service to 6 oz or 180 cc. No more or it will leak . Use hypoid gear lube only. Since switching from amsoil gear lube to bel ray 80w 90 hypoid gear lube 6 oz only I have not had a trace of
A leak. Didn’t change any o rings. That was 10 years ago. I do change it every couple of years.
