Power to headlight went kaput!
- Heavy Armor
- Has liked: 10 times
- Been liked: 25 times
So my bike has developed an intermittent problem of losing all power to the headlight. It's not the bulb, dimmer switch doesn't seem to have any effect, it's just DEAD. And then I'll start it up and it's working again. I certainly don't wanna be caught out at night when it decides to be stubborn. Are there any known connector issues that I need to take a look at? I dread having to pull the fairing again and work blindly through all the wiring!
- Has liked: 481 times
- Been liked: 435 times
Re: Power to headlight went kaput!
Yep, the 10-pin connector is notorious. Left side below the handlebars.
- Chris Cochran (Tue May 31, 2022 3:56 pm) • Bonnie and Clyde (Wed Jun 01, 2022 2:10 pm)
South Jersey Retreads
Patriot Guard Riders
Warriors Watch Riders
- Been liked: 104 times
Take off false tank and left fairing, follow fuse box wire bundle to 10 pin connector . That’s your problem. I cut out 10 pin connector and hard wired everything. That was over 10 years ago and haven’t had a problem since. It’s known to cause electrical problems.
- These users liked VoyKimmer's post:
- Heavy Armor
- Bonnie and Clyde
2007 KTM Super Enduro 950
- Been liked: 50 times
- mayhem8
- Current bike(s): 2003 Kawasaki Voyager 1200
- Has liked: 2 times
- Been liked: 24 times
My bike has been having the same problem. I took off the tank cover, but this must be buried down lower because I could not see it from the top looking down. Lots of connectors, just not a 10 wire/pin one. Was hoping not to have to take the fairing off to get to it. Is this on the left side when sitting on the bike?
FWIW - If I turn the bike on and click the starter, the headlight will come on. Once it's on it seems to stay on, but sometimes when I start it, the light will come on and go off 2 seconds later and stay off. For now, I've just been doing the "starter tick" thing, but this gives me hope for a more permanent fix.
Thanks for posting this.
- Has liked: 228 times
- Been liked: 602 times
I don't think the headlight is supposed to fire up until after you start the bike.
Like all the rest of this bike's circuitry, this is complicated. Involving a solenoid/relay and an emergency circuit to keep the headlight on. If there's really a problem, checking that relay would be on my short list -- right after the 10-pin connector.
- mayhem8
Ticking the starter on mine will fire up the headlight. Not sure if it's supposed to, but I remember seeing that posted someplace else in the forums.
FWIW - I found the 10 pin connector, and Yes, it is buried in there on the left side of the fairing if sitting on the bike. Have not taken the fairing off my bike yet but I can see now I will likely have to do that to get decent access to this connector.
There is a separate lower left and right hand fairing piece that is only held on with 5 screws, but unfortunately taking that off didn't give me any better access to this connector. I was able to push on it, but I'd like to at least take it off, put some dielectric grease on it and reseat it.
- mayhem8
BTW - Does anyone know offhand where the solenoid/relay is located? It really sounds like the solenoid is supposed to be latching, and is intermittently failing to do so. Once it latches, it seems to stay latched, until I turn the bike off and have to start it again,
Headlight (and two others) is sorta behind the headlight under the left fairing, IIRC. The other three or four are under the left side of the fake tank.
Nope, they are not latching. (And all solenoids are identical.) Not sure about this particular circuit, but others have a weird complexity that involves reversing the polarity at places to simulate latching. This is why LEDs don't work in the cruise control lights. And why I hate looking at the schematic. (Enter Dave and his wizz-bang app )
Before turning your brain into tapioca, I recommend just sorting out whether there's actually a problem (lights not coming on when you hit the starter is by design). And if necessary checking the solenoids (I just swap them). You might also buy one (see Dollar for Dollar for $10 replacements), to carry as a spare if nothing else.
Maybe that's all it takes, not actually starting it. I remember a circuit for that ... but I don't remember any other details. Dave sent around on here a readable schematic.
The fairing is easy to get off and on after the first couple hundred times. IIRC, the lower fairings have four bolts. I can usually twist it around without taking off the case savers. The upper fairing has one on each side and two more in the front. It requires taking off the mirrors, that cowling thing, windshield, and headlight surround (and all associated bolts). Be prepared to hold the fairing up while you disconnect the two lights in it -- a really good place for that dielectric grease. I hold it between an elbow and a knee so I can use both hands on the stuck connectors. (Else pull the light sockets from the fairing.)mayhem8 wrote: ↑Wed Jul 06, 2022 9:56 pmHave not taken the fairing off my bike yet but I can see now I will likely have to do that to get decent access to this connector.
If you pull the right fairing, check the cruise control cable slack. Often goes out of adjustment.
- mayhem8
FWIW - I was able to see and push on the 10 pin plug mentioned previously, without removing anything but the faux tank cover. So far, the headlight issue has not happened since. Whatever the problem is, it's on the hairy edge of working/not working.
So clip that cable tie to remove the tension.
- GrandpaDenny (Tue Jul 12, 2022 12:50 am) • cushman eagle (Tue Jul 12, 2022 12:59 am)
- Been liked: 134 times
have you had any problems with starting the bike ? ie, starter will not spin ? the headlamp relay is somehow wired into the field to the starter relay. I found this out when I installed a fuel primer button , If you depress the primer button after the bike starts the headlamp relay will drop out.mayhem8 wrote: ↑Wed Jul 06, 2022 10:02 pm BTW - Does anyone know offhand where the solenoid/relay is located? It really sounds like the solenoid is supposed to be latching, and is intermittently failing to do so. Once it latches, it seems to stay latched, until I turn the bike off and have to start it again,
Gene Kap.
- mayhem8
ekap1200 - I've not had any problems starting the bike.
As an update, while I couldn't really get good access to the 10 pin connector with the fairing on, I was able to simply push down on the connector. Probably jinxing myself, but the headlight has been behaving since then.
Might be worthwhile to get a tie wrap around the connector, if you're not into taking it apart and cleaning things up.
- cushman eagle (Thu Jul 21, 2022 12:35 am)
- Current bike(s): 1989 Voyager XII
- Been liked: 15 times
I've had this same problem in the past.mayhem8 wrote: ↑Wed Jul 20, 2022 6:41 pm ekap1200 - I've not had any problems starting the bike.
I cut the white wire with the black stripe on each side of the 10 pin and soldered a short chunk of wire between the two pieces and have had no more troubles with the headlight going off.
- These users liked sheiserman's post:
- GrandpaDenny (Fri Jul 22, 2022 4:44 am) • Bonnie and Clyde (Fri Jul 22, 2022 2:04 pm) • cushman eagle (Sat Jul 23, 2022 12:53 am)
- Rating: 33.33%
- Bonnie and Clyde
Thanks for sharing that detailed fix. A+sheiserman wrote: ↑Fri Jul 22, 2022 1:10 amI've had this same problem in the past.mayhem8 wrote: ↑Wed Jul 20, 2022 6:41 pm ekap1200 - I've not had any problems starting the bike.
No problem. I farted around with this for two seasons before just fixing it.
I had even gotten accustomed to pulling off on the shoulder when it was dark out and using a flashlight to find and push down on the 10 pin. I'd just quick undo the thumb screws at the front of the tank cover, lift it up and tap the connector , tighten the thumb screws and be on my way again. The last time it happened there were barking dogs involved and I had to take back off before I got the light on. I rode two more miles with flashers only before I could try again.
Never did see the dogs.
- Bonnie and Clyde (Sat Jul 23, 2022 3:34 pm)
- Bonnie and Clyde
I have a couple week trip planned in September 4k miles + or -. I am going to just solder those wires pre-trip to avoid any headlight issues hopefully.sheiserman wrote: ↑Fri Jul 22, 2022 1:10 amI've had this same problem in the past.mayhem8 wrote: ↑Wed Jul 20, 2022 6:41 pm ekap1200 - I've not had any problems starting the bike.
