lights and gauges out
mikey
Current bike(s): 2003 kaw voyager 1200
Post by mikey »
hello all, i have a small problem, i went to start my voyager and all the dash lights are out plus the tack and all the gauges don't work, i checked the fuses and they look to be good. has anyone got any ideas what it could be :Cball
thanks for your help
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Re: lights and gauges out
Post by carl leo »
if the dash is all that is affected check the oil pressure sender on the side of the oil pan. if it is damaged it will kill the circuit. best way to check is to take the wire off the sender and see if the lights are restored.
:hpdc: :hpdc:
mikey
Post by mikey »
also the head light is out i just seen that this morning, but the turn signals work?? is that sender wire underneath the bike?
thanks
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
if the headlight is also out, check the white multi-plug under the left upper fairing, it is a 10 wire plug. this plug sometimes gets nasty and needs cleaning. wire brush on the connectors and some dielectric grease should restore your lights..
jek7galo
Current bike(s): Kawasaki ZX-12R - 2000
Kawasaki Voyager XII - 1995
Post by jek7galo »
Hello friends, happy new year to all
My name is Jeferson from South Brazil, the last user from 2014 ... i have a Voyager 95 and have the same problem. The meter, head ligth and break, do no light more. We check the wires, connectors, relays, but dont tur on and we believe that be IC Igniter..
someone could give me a hint ?
best regards
Kawasaki Ninja ZX-12R - 2000
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
the IC igniter can not cause this problem, check the white multi-wire plug under the left hand fairing, this is the fault almost every time....
:hpdc:
jek7galo
Post by jek7galo »
I already check the all plugs, but tomorrow i check again te white plug with 10 wires..
You said to check the sender oil pressure, if he dont work, cut the circuit ??
thank you very much friend
jek7galo
Post by jek7galo »
Hello Carl Leo,
The plug have one wire burn, i did the jump in the wire and solved my problem.
Thank you very much
jek7galo
Post by jek7galo »
Yes, i had cut wire and unite out the plug .. :wnk2:
richardb, austin
Post by richardb, austin »
Carl is a not-too-bad source for repairs. He's only been wrong once. That was when he thought he'd made a mistake but in reality he hadn't. :gig:
richardb, austin
__________________
carl leo
Guru
Guru
76 kz900 LTD
60 NSU supermax
Post by carl leo »
huh!
:bat:
csheafer
4
Current bike(s): 92 Kawasaki Voyager VII 1200
Post by csheafer »
I am having the same issue.
Checked the white plug, all good.
But I did develop a bad oil leak and someone mentioned oil sender or something wire.
Its covered in oil but not burned.
Do I cut this wire to get me home?
Im stranded.
