Choke cable
- Current bike(s): 1986 Kawasaki Voyager XII
Choke cable
Anybody know where I can get a choke cable for my 86 XII? I've done some looking online, but only find one on ebay that is for an 87-2000. Did the cable size/design change from the 86 to the 87?
"It didn't take them long to try him in their court of law
He was guilty then of thinking, a crime much worse than all."
- Has liked: 83 times
- Been liked: 140 times
Re: Choke cable
Contact Carl Leo, his contact info is on the main page. He helped me out with mine a few years ago and gave me priceless advice!
Plus saved me a ton of aggravation!!
- debron
Re: Choke cable
Carl's info is not on the main (or any) page and hasn't been for almost a year. You can find his contact info in the "Members" section (top right in the menu bar.)
Re: Choke cable
Thanks! Sent him an email. The choke cable is more of a nuisance than a problem, but I definitely want to take care of it.
Re: Choke cable
The thumb adjuster on the handlebar separates/splits in half, DO NOT try to twist it off or twist when separating. Just pull apart.grayblob wrote:Thanks! Sent him an email. The choke cable is more of a nuisance than a problem, but I definitely want to take care of it.
Re: Choke cable
Hi Everyone,
I do not know if my choke switch was replaced before I got my 95 Voyager, But I had to replace my choke switch it was a solid ring. I ended up Taking off the L/H controls and the hand grip and sliding off the old switch and sliding the new one back on. I even got the new
part from Kawasaki.
part from Kawasaki.
- metric
Re: Choke cable
I just change mine and is not to bad, when you install it on the bike start with the handle bar first and than the carburetor slide, for me was easier like that.
02VoyagerXII AVA#5443
Re: Choke cable
Thanks for all your tips!
Re: Choke cable
I received an email from Carl with a part number so I can order the cable. It turns out that I had seen the cable in some parts diagrams, but the part was labeled "cable, starter” so I didn't consider that it could be the correct part.
I'm thankful there are such great people here that are willing to share their hard earned skill and knowledge.
- Current bike(s): 1986 Kawasaki Voyager XII ZG1200
Re: Choke cable
What is the part number for the choke cable? I am looking to replace mine on my 86 Voyager XII
Re: Choke cable
I just changed mine tonight. Once I got rid of the added junk two owners prior put in place of the choke cable (a silly finger push that was annoying as heck), the cable went in easily. I did just like everyone else said, start at the hand control end and work down to the carbs.
Thank you again!!
Thank you again!!
