Brake light switch
pastormike
Brake light switch
Post by pastormike »
How does the front brake light switch work? Power feeds both small spade inputs, but when the switch is activated there is no power going thru the switch. Checked for continuity with my meter and when switch is activated (pushed) there is no continuity between any two poles. I'm either totally confused or the the switch is bad. I have no brake lights. Thanks for the help.
Re: Brake light switch
those two switches are for activation of the brake light and the disconnect for the cruise control. If you ohm the switch one should be normally open the other normally closed if I remember correctly. Those switches have gone bad before, try spraying a contact cleaner, available still at Radio Shack and see if they work. You should hear a clicking when the lever is pulled indicating the contacts are working. If you aren't getting any brake light or cruise after that check the fuses. You may need to replace the switches if the bike stays out in the weather a lot.
Sometimes a meter can give you a wrong reading, use a test light and see whats happening.
Dose the rear brake put the lights on.
:thmup:
pastormike
I'm not sure the problem is my switch. Cruise works fine, but I have no brake lights. Could it be in the "ignitor"? I'm no mechanic, but I understand basic wiring, but I can't run the wires from switches all the way to the brake lights to see if there are breaks in the wires. HELP
There is a relay above the headlight that can go bad
Has liked: 852 times
Pastormike,if you take a close look at the front brake switch,you should see two switches as Mr Jensee said.One is for the cruise,the other for the brake light. The ignitor is not in that wiring circuit.Mr Jensee discribed the action of the two switches.I hope you find the answer to your problem soon. :help:
pastormike
Ok. I'm making progress. Found the brake light relay & it seems to be good. I can feel it switching & I tested it with Ohm meter. Took a wire directly from battery & touched it to one of the brake light terminals & get lights, so I know the circuit is good. I have hot on the relay side of the relay, but no hot on the line side. When the relay closes the switch shouldn't it close a hot circuit to the bulbs? Hope that makes sense. Can't seem to find the wiring diagram I need.
the one in the lower left corner is a color diagram
http://zg1200.com/ZG1200/ZG1200_Voyager_XII.html
:thmup:
1ReddRyder
1992 Harley Davidson Electra Glide FLHS
1340 EVO
Has liked: 7 times
Post by 1ReddRyder »
Just went through the no brake lights thing today on mine !!! there were no dash lights also,,,so replaced fuse and dash lights and all other lights were working,,,,but no brake lights,,,took fairing off,,cause I could hear the solenoid engage,,,wasn't sure if it was good ,,,so after dark with head lamp on,,,in the fuse box I see,,,what each fuse is For !! ahhhh yeah Brake ,,,replaced that Bad Boy and zha ZaM !! hand brake activated solenoid and Brake Light WORKS
not easy to see under the fuse box lid,,, they are hard to read :wnk2:
dang ,,,lot of frustration :bat: and work :hpdc: ,,,but determination and patience with a prayer :pray: for some divine intervention and we back RidiN !!! :clap:
