[img]http://i27.tinypic.com/ih1mcn.jpg[/img]
This was a painted over lens. I used rubbing compound (heavy duty) to remove the paint on the outside. I then used a fine polishing compound to remove scratches on the lens. To get the light apart, I put the whole assembly in our electric stove oven set at 175 deg. I left it in there for 15 minutes and after removing three screws previously, I slowly pulled the two halves apart. If it is hard to do just put it back in the oven for a longer period of time. (I guess I should tell you that I put the lens on a piece of cardboard in the oven so that the wire grate would not burn into the plastic).
After getting the lens apart. ( don't pull too hard, it will come apart easily if hot enough) I removed the paint on the inside of the lens with Acetone. It came off with a rag really easily.
Before putting it back together I painted the interior of the lens (not where the light will come through) with Plasticote chrome paint. Then back into the oven to warm up at 175 deg and press together. Do not remove any of the glue that is on the lens. This glue will soften when heated and reharden when cooled. Got a question? Ask away! :D
tail light lens
- David (N. Alabama)
- Has liked: 83 times
- Been liked: 140 times
And what about the emblem (Voyager)? How did you reattach it or did you opt to leave it off and make folks wonder what kind of bike it is (those who don't know a Kaw).
- Kevin B in Illinois
1990 Kawasaki Voyager XII
2009 Kawasaki Vulcan Voyager
1969 Kawasaki Sidewinder 250
1965 Kawasaki F2TR 175
