Electrical advice
BLESSED1277
Current bike(s): 1995 KAWASAKI VOYAGER XII
Electrical advice
Post by BLESSED1277 »
I am having problems with my hazard light on the right side of the bike also my front brake doesn't activate my brake lights. I need a diagram or maybe someone can help with this issue.
debron
Re: Electrical advice
Post by debron »
I have a large (4375 x 3115 meg. pix., 1.7 mb) jpeg wiring diagram I can email to you. Let me know your email address.
Before you get too involved in the wiring issue. Get some contact cleaner (they may still sell it at Radio Shack) and spray the switch under the brake lever, the one behind the cover behind the brake pedal, and the bulb sockets. If you can find a tiny bristle brush that helps with the sockets. Then test the lights and brake. Sometimes a film builds up due to age and weather that corrodes these contacts.
BLESSED1277
I've tested the switches an the contacts an they work. I also noticed that the right indicator doesn't come on if the hazards are on.
suzib6sw
Tourer
Tourer
Post by suzib6sw »
Does the running light on the right front work?.. Also does the rear turn signal work as well?.. Either on the flash or on the hazards?... Does the turn signal on the right on the Dashboard work?..
I suspect a break in the GREY wire as it comes from front and rear bulbs and the hazard switch.. If the ground wire (yellow/black) was broken, the front running light would be out too.. Im also assuming the side markers are working..
Pete
Pete
BLESSED1277
I think i have found where the problem is its in the the wiring harness on the right side of the bike where the brake light an starter button plugs in at i disconnected it an used the wiring diagram that i got from the forum an started jumping the terminals on the female side an the bike started i think either its the start switch or a brake between the switch an the harness. thanks everyone for all your help.
