radio resets after each on off cycle...why?
- Current bike(s): 1200B17
why does my radio & clock reset after each on/off cycle?
- Gator Mike
2002 Honda 750 ACE
Re: radio resets after each on off cycle...why?
probably the fuse is blown that keeps the memory on. Fuse is located behind the headlight........Gator Mike
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Welcome to the forum. You will find more about the XII than anywhere else. Consider joining the AVA. You will find alot of good people here.
- suzib6sw
There are two fuses.. the 3amp in the fatter in line fuse holder which is the main power to the radio..
the 1 amp is the battery back up and is in the thinner of the two holders..
Also check the 3 amp fuse under the false tank in the fuse box.. Sometimes that blows..
Cheers..
Pete
Cheers..
Pete
Pete
