Bulbs... What goes where?
Muleears
Post by Muleears »
I want to convert what I can to LED but I don't have the bike here to pull the old ones out. I think the brake light is an 1157. Is there a chart somewhere that tells me what bulbs go where? I'm primarily interested in tail, turn, and other marker lights. Sorry for the simple question but I'm a little handicapped with the bike 80 miles away. I'd like to go ahead and order the LED's so I have them when I get it back. Any help is appreciated! :thmup:
Cal
'02 Voyager XII 22K miles
Hampton Roads, VA
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Re: Bulbs... What goes where?
Post by gearheadfla »
Brake lights, 1157
front turn , 1157
rear turn , 1156
side markers frt and rear 196 You will also need to replace the flasher for a LED flasher, avail and Auto Zone or most car part stores
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
Muleears
Post by Muleears »
gearheadfla wrote:Brake lights, 1157
front turn , 1157
rear turn , 1156
Thanks gearheadfla! That's exactly what I needed. :thmup:
Cal
Hampton Roads, VA
Muleears
Post by Muleears »
I replaced my front turns with some amber 48 LED bulbs I found on Ebay today. They look great! I was worried about them fitting as they are longer than the standard bulb but no problem. I replaced the brake lights with some 24(I think) LED red bulbs. They are OK, I may try to brighten up the backend a little. I like to be seen :thmup: :thmup:
Some additional lights, maybe an LED light bar and a BACK OFF modulator. Anyway the front turns are a definite improvement.
Now if it would just warm up a little I'd go for a ride! Even though my inspection is two years out of date :devl
Cal
Hampton Roads, VA
Muleears
Post by Muleears »
Stupid question of the day :hmm: . I didn't notice when I first got the bike if the turn signals were on all the time and only blinked when activated. Since I have installed the LED's that's how mine operate. Is this correct? Or should they be off and only illuminate and blink when activated? I have not added an LED flasher, could this be related?
Cal
Hampton Roads, VA
chevyman1
Been liked: 16 times
Post by chevyman1 »
Muleears wrote:Stupid question of the day :hmm: . I didn't notice when I first got the bike if the turn signals were on all the time and only blinked when activated. Since I have installed the LED's that's how mine operate. Is this correct? Or should they be off and only illuminate and blink when activated? I have not added an LED flasher, could this be related?
Not a stupid question the front turn lights should be on all the time.
You will have to install a electronic flasher for the turn signals to flash proper but that's not your problem. The running lights circuit is separate from the turn lights circuit (should be 1157 double contact bulbs)
That said when I put LED bulbs in the front of both my voyagers the running lights would not light or lit vary dim, I checked voltage, polarity and the sockets, hooked the sockets up to the battery and the bulbs would light but in the light circuit they don't. couldn't find the reason so I ended up leaving them regular bulbs.
The LED's worked everywhere else.
If anybody can shed some light on this problem I would like to know why that is
