I can't find it! Tip-over bar brace thread.
Muleears
Post by Muleears »
I know I read a thread about this somewhere, I have searched and searched but apparently I'm using the wrong terms. I want to find the thread that dealt with installing a bar, some said towel bar, some said water pipe, between the tip over bars on the front of the engine. Anyone point me in the right direction please? :tho:
Cal
'02 Voyager XII 22K miles
Hampton Roads, VA
Lucasind
and a bunch of parts !
Has liked: 194 times
Been liked: 69 times
Re: I can't find it! Tip-over bar brace thread.
Post by Lucasind »
...... it's right here in this column, " highway pegs"... by Rhbrandy
Muleears
Post by Muleears »
Lucasind wrote:...... it's right here in this column, " highway pegs"... by Rhbrandy
Thanks. Never thought of searching Highway Pegs :hmm:
:thmup: :thmup:
Cal
Hampton Roads, VA
grumpin
Post by grumpin »
What I have found helpful is to bookmark the topic, and then it is in your user control panel under manage bookmarks. I use that because I will forget what the post was called etc.. :hmm:
Dane
2000 Voyager
suzib6sw
Tourer
Tourer
Post by suzib6sw »
May want to look for Light Bar..
Pete
Pete
Muleears
Post by Muleears »
suzib6sw wrote:May want to look for Light Bar..
Pete
Thanks Pete, that is my ultimate goal but I have been unable to find one. Apparently no one makes an aftermarket bar that goes in the same place. If someone does please point me to them. In looking at my bike I determined that someone had already tipped the bike over as the "tip over" bars are already bent... :tho: To make matters worse, it appears to have been tipped on both sides as they are both bent! :tho: :tho: Now my first project is going to be taking them off and bending them back to somewhere near proper arrangement. Any suggestions on how to do this? Or should I just toss them and find some new?
Cal
Hampton Roads, VA
Tat2demon
Current bike(s): 78 Yamaha XS 1100
81 Yamaha XJ650
88 Kawasaki Voyager XII
Post by Tat2demon »
Pete
From the D4D page - Voyager XII Shifter & Driving Light Bar - Shifter for VXII. Also have a steel bar that would go between front tip over bars to strengthen and provide location for driving lights, black painted finish. For more information, contact Allen Boethel (The Hippi). The email link on there doesnt work so Im not sure if he is still reachable. Looks like its probably oldhippi59@yahoo.com.
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
doug of so fla
Current bike(s): 07 gold wing
Post by doug of so fla »
Muleears:: If the tubes themselves are not bent, It would be easier to strraighten each unit while still on the MC. If the tubes are bent it would be better just to get some off e-bay. They are just mounted on metal ears and if not bent real bad should be ok, Just grab hold and pull or use a lever. A 1" alum bar is not expensive and anyone, or small machine shop, with a metal lathe can turn the ends down, and should not charge $10.00 to do it, takes about 10min and then you can polish it up to a good shine. A stainless bar is about $30.00 and still not a problem to turn it down, and polishes up real nice. Good luck with the project.
Muleears
Post by Muleears »
doug of so fla wrote:Muleears:: If the tubes themselves are not bent, It would be easier to strraighten each unit while still on the MC. If the tubes are bent it would be better just to get some off e-bay. They are just mounted on metal ears and if not bent real bad should be ok, Just grab hold and pull or use a lever. A 1" alum bar is not expensive and anyone, or small machine shop, with a metal lathe can turn the ends down, and should not charge $10.00 to do it, takes about 10min and then you can polish it up to a good shine. A stainless bar is about $30.00 and still not a problem to turn it down, and polishes up real nice. Good luck with the project.
I'm sure the tubes are bent Doug, I know its more than just the mounting ears being bent. I guess I'll look on ebay. Thanks for the suggestion about the other stuff too. :bowdn:
Cal
Hampton Roads, VA
Bill from Baltimore
Current bike(s): 2003 voyager
Post by Bill from Baltimore »
look under highway peg thread
Chris near Kansas City
I have bent them back (if they aren't bent too bad) by clamping the ear in a vice and tweaking it back. I use a solid aluminum bar in between the crash bars. 7/8" inch if I recall. Light sanding on the bar and a flapper/drum sanding on the inside of the crashbars so everything goes together semi-easily. The tension once everything is tightened down makes the whole unit really solid. Couple Kuryakyn Magnum Quick clamps for light mounts and it's time to hit the road. You could get a shower rod or stainless tube and sleeve the aluminum rod so that the crash bar and tie bar are the same diameter all the way across.
Muleears
Post by Muleears »
Chris near Kansas City wrote:I have bent them back (if they aren't bent too bad) by clamping the ear in a vice and tweaking it back. I use a solid aluminum bar in between the crash bars. 7/8" inch if I recall. Light sanding on the bar and a flapper/drum sanding on the inside of the crashbars so everything goes together semi-easily. The tension once everything is tightened down makes the whole unit really solid. Couple Kuryakyn Magnum Quick clamps for light mounts and it's time to hit the road. You could get a shower rod or stainless tube and sleeve the aluminum rod so that the crash bar and tie bar are the same diameter all the way across.
Thanks Chris. I've been able to bend the right one back into position. I will continue to work on the left, access is the problem. I have bought a 24" piece of black iron water pipe that I will cut to fit between the tip over bars. I also have a 24" chrome towel rack on the way to place over the water pipe to make it look pretty. On my ebay watch list is two different pairs of bars if I can't get this straightened out! :thmup: :thmup:
Cal
Hampton Roads, VA
gearheadfla
1989 Voyager XII
2007 Vulcan Nomad
2006 Honda Rebel
Post by gearheadfla »
Found this one on Flea Bay about a year ago, it's power coated and someone is making them, I don't remember who it was, I'll see if I still have the invoice for it, and yes I just took this pic for this tread, and no I haven't put it on the bike yet, I got to get that done someday.
Jim in Fl. 88 XII
89 XII-parts bike-scraped
01 XII-sold
07 Vulcan Nomad
Patriot Guard Rider, Florida.
Sunshine State Voyagers
Has liked: 83 times
Been liked: 140 times
Jim you should be able to check your purchase history on eBay &/or PayPal to identify the seller. :hmm:
Also if you're not going to use it I'll take it of your hands. If anything, just so it doesn't feel neglected!
:gig:
Bill O
2003 1200 Voyager
Been liked: 6 times
Post by Bill O »
gearheadfla wrote:Found this one on Flea Bay about a year ago, it's power coated and someone is making them, I don't remember who it was, I'll see if I still have the invoice for it, and yes I just took this pic for this tread, and no I haven't put it on the bike yet, I got to get that done someday.
If I'm not mistaken, it was Harrison Specialties who were re-manufacturing this light bars. The quality was very good. I also believe he has since stopped making them. At one time he advertized in the Voyager Voice.
I believe this is the current link to his webstore: http://www.harrisonspecialties.com/bran ... lties.html
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
