Blown fuse
Tat2demon
Current bike(s): 78 Yamaha XS 1100
81 Yamaha XJ650
88 Kawasaki Voyager XII
Blown fuse
Post by Tat2demon »
Got my radio back from Pete today.
Put it in, hooked up the harness and turned the key. No lights so i checked the fuses. The acc fuse was blown. Popped in another, turned the key and it blew right away. I unhooked the radio harness to take that out of the equation but still happens.
I know next to nothing about electrical work so don't have a clue where to start or what to look for. Any help its greatly appreciated.
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
Been liked: 134 times
Re: Blown fuse
Without being there the only advice is, to start with where you have been working. What have you taken apart, and put back on. look at all your work, you may have pinched a wire somewhere between something. Good luck
Tat2demon
81 Yamaha XJ650
Re: Blown fuse
Post by Tat2demon »
Dang, Ive been working on the entire bike front to back with everything torn down. This isn't going to be fun.
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
Tat2demon
81 Yamaha XJ650
Re: Blown fuse
Post by Tat2demon »
Well I got it figured out. It was just as l suspected, I've had an idiot doing all my work (me). One of the connections in the trunk area was resting on the frame.
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
Lucasind
and a bunch of parts !
Has liked: 194 times
Been liked: 69 times
Re: Blown fuse
Post by Lucasind »
TAT2DEMON....I like to say that a little differently.......... " I was testing out a particular circuit using my fuse block. Test results : The FUSE was working perfectly" :gig:
Tat2demon
81 Yamaha XJ650
Re: Blown fuse
Post by Tat2demon »
That sounds much better! :-D
Nate
78 Yamaha XS 1100
81 Yamaha XJ650
