Hi guys
Today, while returning home I noticed the leak, leaked a few drops. Leaking from the canal head. http://www.fotosik.pl/pokaz_obrazek/39c ... b2654.html
http://www.fotosik.pl/pokaz_obrazek/b24 ... d5d2d.html
Should I think about replacing the head gasket, or could be some sort of other reason?
gery
Leaking head gasket?
- gery
- Has liked: 106 times
- Been liked: 277 times
Re: Leaking head gasket?
Gery;
that appears to be the drain hole from #1 sparkplug. Perhaps the pipe from the cylinder head to the rubber hose leading to the thermostat housing is leaking, or a loose hose clamp on the aforementioned. I hope that's it,
Gery,
Please let us know what you find out with that leak!
Thanks,
lockwoodjohn
Thanks,
lockwoodjohn
- gery
Definitely. Today, even after firing the bike I discovered coolant leak.
Interestingly, a few kilometers later, there were no leaks. Today undress the machine and see what and how.
- gery
Luckily it was only a coolant leak. Come loose strap under the battery and the liquid flows into the spark plug hole and then leaking out through the drain holes.
Thanks gentlemen and greet gery
