2014 Post-rally tech tip #1
- Chris near Kansas City
Take the door off your left hand fairing pocket and remove the foam that used to keep the cassette tapes from rattling around before it gets too old and turns to goo in the heat and goos up everything that touches it like the AVA kickstand pad, or the pen you got from your bank/church/work/wife or your wallet.
- Ditto
Re: 2014 Post-rally tech tip #1
Did that.Take the door off your left hand fairing pocket
Did that.remove the foam that used to keep the cassette tapes from rattling
Did not do that.before it gets too old and turns to goo in the heat and goos up everything that touches it
Try to warn me a little quicker next time.
Thanks for warning everyone else cause it does make a mess.
Gary (Ditto) GA
2001 Voyager XII (Parts bike)
- ghostler
- Has liked: 2 times
- Been liked: 10 times
Thanks for the tip. Does any one have a suggestion for replacing the weatherproofing on the fairing pocket door? Mine is completely weathered and cracked.Chris near Kansas City wrote:Take the door off your left hand fairing pocket and remove the foam that used to keep the cassette tapes from rattling around before it gets too old and turns to goo in the heat and goos up everything that touches it like the AVA kickstand pad, or the pen you got from your bank/church/work/wife or your wallet.
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
Clovis, NM, US
1971 Honda CB100
- Current bike(s): 1999 KAWASAKI VOYAGER
2005 HARLEYDAVIDSON SPORTSTER - Location: Kansas City , Missouri
You might look at the foam weatherproofing tape used to seal the space between a camper shell and a pickup truck bed. It would have to be cut to fit but most have a adhesive backing to them or---- something along those lines. I work in the auto collision industry and have seen several products like that. I will keep my eyes open for a better solution for you. Good luck, Robert Beers
