Bad sound around 60mph
CHUCKLES
Current bike(s): 95 voyager,96 vmax
Post by CHUCKLES »
Hey can anyone help me with this problem, around 60 mph I get a terrible whine from what I thought was the rear wheel so I replaced the rear wheel bearings and while I had the wheel off I went ahead and replaced rear tire also and it was about time anyways. After doing these things the whining is still there, it almost sounds like a four wheel drive truck with mudders on it, it's weird that it only starts around 60, I don't want to just start throwing parts at it. Any ideas will help. Oops sorry it's a 1993 VOYAGER with 25,000 miles on it. Thanks and have a great day
Has liked: 854 times
Re: Bad sound around 60mph
Have you checked,or ,maybe replaced the rear end gear oil? I am running synthetic 75W-90 in mine.It is possible the rear end is not set up perfectly,which could cause the whine, or the axle bolt my be too tight.I feel synthetic tends to quiet gear noise down somewhat from experience in our truck fleet.
Lumpy Rider
Current bike(s): 2001 Voyager
2003 Suzuki Intruder
Post by Lumpy Rider »
Since the noise is the same with the new tire as it was with the old, I would suspect the final drive unit and would start by checking and/or changing the gear oil. Yours may be dry. I had it happen on other bikes where the fill plug had been damaged/cracked by over tightening, or had a defective or missing o-ring, either which could cause the oil to leak out over time. A dry final drive could certainly emit a whine noise.
CHUCKLES
Post by CHUCKLES »
I did check the gear oil it is full, but I didn't change it, I'll give that a shot. Someone said it could be the driveshaft, man I really dont want to tackle that one, thanks for the help guys maybe change of fluid will work (cross my fingers) thanks again
Lumpy Rider
The transmissions do whine and loudness I think is subjective. Another possibility is to adjust the balancer gear backlash, explained in the AVA tech center. No out of pocket to do this.
CHUCKLES
Post by CHUCKLES »
I did the balancer adjustment already it was still there but thanks giving me some help with this. Does anyone else have this whine between 60-65 mph ?
Lumpy Rider
Rode my Kawi today and did notice a pronounced, high pitched whine at around 60 mph. Less pronounced under and over this speed. Possibly inherent to the VXII. My Suzuki LC 1500 howled at around 65 when it was new and did this for the 10k miles I rode it sans any mechanical problems.
CHUCKLES
Post by CHUCKLES »
Well maybe this is a normal sound, but I don't think it's supposed to sound this was especially with only 25,000 on it. It's a great running and smooth motorcycle , I would really like to find out what is causing this, if a certain speed make the problem show up it seems to me it's a drivetrain problem right?
96desertXII
Post by 96desertXII »
Mine has a pronounced whine most of the time with 90K on the clock
Chuck & Ruthie
1989 FLHS (sold)
2009 FLHTCI (sold)
2005 FLHRI (sold)
2003 FLHTCU (sold)
1978 GL1000 (sold)
1978 CB750K (sold)
1958 FLH (stolen)
Tom(North Alabama)
Current bike(s): 2002 Voyager II
2002 BMW k1200LTE - sold
Post by Tom(North Alabama) »
Check out this thread....
http://www.amervoyassoc.org/forum/viewt ... ilit=whine
Some Voyagers are alot louder than others, some don't whine at all
Hope this helps...
'02 Voyager XII
'08 Concours 14 - sold
'02 BMW K1200LTE
CHUCKLES
Post by CHUCKLES »
Well the last post pretty much tells me that it's just natural for some of the voyager trannys to whine, if that's the case I'll try the synthetic 75w90 and if it helps than great if it doesn't I'll do like the other gent said and turn up the radio and ride on with a smile . I've just join this site and I have to say all of you have helped a new voyager rider a lot and I thank you all for your help maybe someday I might be able to help you. Thanks again and ride safe.
drdoolittle77630
Current bike(s): 93 voyager 1200
2002 voyager 1200
2000 klr 650
Post by drdoolittle77630 »
ive owned 3 voyagers 1 1984 1300 a 1993 1200 and a 2002 ...the 2002 is the quietest but it still makes a whine at about 60 and again at about 85 ...both of the 1200s do that the thing that helps the most is to synchronize the carbs .....but evenafter that some whine is still there
I think this overwhelming whine you are experiencing is normal. The bike doesn't have a loud engine or exhaust. My bike on a recent trip to Texas and back had a noticeable loud whine between 60-70 mph as well. I have found nothing wrong with my 2001. The faring manages to knock off a lot of wind and engine, transmission and rear end sounds are easier to be noticed and amplified behind that shielding, especially if you are not listening to the radio. If the bike isn't doing anything else abnormally but the whine, I would just get used to it if I were you or buy a new Voyager with a belt drive.
gery
Current bike(s): voyager zg 1200 2003
Post by gery »
In my it was loud (to yesterday). What to do?
1 Change to synthetic oil 75W,
2 drill a vent hole
Now that is a different ride. It's quiet and there are no leaks.
gery
