After some searching i found this what looks to be an ideal solution for a subwoofer on our bikes. This Kenwood slim line powered unit will fit nicly in the trunk of the Voyager and comes with both high level speaker inputs and a line in. It also has a wired remote that lets adjust the High pass filter and level.
http://www.amazon.com/Kenwood-KSC-SW11- ... roduct_top" onclick="window.open(this.href);return false;
This may very well be the most ideal sub for a bike around and it sure does not break the bank.
The frequency response is decent also at 35-180Hz
Subwoofer for the bike in the trunk
- Tonyvdb
- FBT
- Current bike(s): Today:
My teal and black 1993 Voyager XII
In the past:
1987 Voyager XIII
1981 Honda Goldwing GL1100 Interstate
1982 Honda Silverwing
1981 Honda Silverwing
1980 Kawasaki KZ1000 LTD - Location: Jacksonville, FL
Re: Subwoofer for the bike in the trunk
Hope you don't rattle that 20 year old plastic off the bike!
Tim in Jacksonville, FL
1993 Voyager XII Owner
- Tonyvdb
LOL, just want to fill out the bottom end of the system as it needs it. Not trying to wake up the neighbors.
- suzib6sw
I looked at these too..
They should be fine , except the power requirements..
Dont forget , the Voyager Stock alternator is 35 amps MAX (420 Watts) and with all incandescent bulbs , ignition system, and general load requirements, its running pretty close to the wind.
I would suggest a direct to the Battery supply switched via a relay keyed to the ignition acc circuit.
I will try and dig into the specs more .. may have to end up with a reservoir cap too..
Pete
Edit:
8.5 Amps at 12 Volts at full power = about 100 W .. so, it "should" be ok at normal listening levels..
At full bore, be prepared to replace the trunk hinge and catches.. :-)
At speed, im having doubts as to the effectiveness of a device behind the listener.. But...
Pete
Edit:
Pete
- Tonyvdb
Thanks Pete, Im going to be using it mostly for in city riding. I also wont be running it very hard so likely not ever near its max amp draw.
Ive already abandoned the CB and disconnected it, replaced all lights except the headlight with LEDs so that should help plus you did my radio a few months ago.
Now just waiting for the city to get the gravel off the roads and go for a ride. It was 55F (16C) here today already lots of people jumping the gun and going for a ride even though the side streets still have some slush.
