no power to radio?
- Current bike(s): 2012 Kawasaki Voyager 1700
no power to radio?
i got my 98 Voyager back together after spring cleaning and maintenance and i have no power to radio. My display has not worked for a few years, but i always had radio. I have checked and replaced the 2 in line fuses located behind headlight, but still no power. Any ideas?
- Tonyvdb
Re: no power to radio?
Have you checked the connectors, they have a tenancy to get water in them and corrode. Sometimes just taking them apart and putting them back together is enough to get it working again.
I have changed all the fuses and still no power. Will have to take fairing off to check connections.
- doug of so fla
With no display there is a good chance you have your "HS" (Head Set) button on, but you cannot see it. The radio defaults back to original settings when power is lost to it. Try pushing it in with radio on and be sure volume is up which you cannot see either.. Also make sure mute buttons front & rear are not pushed in.kawman12 wrote:I have changed all the fuses and still no power. Will have to take fairing off to check connections.
Also the two wires that hold the fuses at the back of the radio may be cut right where they enter radio they sometimes rub on the entry hole to the radio and short out. Best advice is to do a search on the forum for: suzib6sw He is our radio expert and he can help you with just about any problem you have with the radio. Call him or PM . I do not know if there are any displays left anymore but he may be able to get you one. Getting the radio up without the display is a crapshoot because of it defaulting back to original setting and the settings sometimes are not the same on all XII's Good luck hope this helps
I know about the HS button as that has stumped me before. Problem is I cannot get the radio to turn on. Even with no display, the radio would always light up. it's as if there is no power going to radio at all.
- doug of so fla
kawman12 wrote:I know about the HS button as that has stumped me before. Problem is I cannot get the radio to turn on. Even with no display, the radio would always light up. it's as if there is no power going to radio at all.
Next thing I would do is: pm, or e-mail, Pete F. AKA : suzib6sw, do a search under "members' above in the "s" easy to find and he can walk you thru amp & radio problems as well as connections. He knows the XII radio & connections very well and is always there to help. He has repaired & modified many XII radios for XII members..
I found the problem was the 7.5 amp fuse. I swear I checked it before, but must have missed it somehow. All is well now.
- doug of so fla
Great!!! thanks for posting the the result of your repair. Will assist others not to give up. Sometimes it is the simple thing & others it can be a real PIA!!
- Been liked: 134 times
kawman12 wrote:I found the problem was the 7.5 amp fuse. I swear I checked it before, but must have missed it somehow. All is well now.
- Tonyvdb
Glad to hear it was a simple fix.
