Hello friends,
Once again, I comming ask for help.
The radio of my bike dont turn on after I pass a hole, but the clock is on.
I veryfi the cables and the botton on\off but dont turn on radio.
Someone has gone through it?
Thanks.
radio dont turn on
- Tonyvdb
Re: radio dont turn on
There are two fuses located just at the rear of the radio. One of them has either gone bad or maybe the connector came apart.
- jek7galo
- Current bike(s): Kawasaki ZX-12R - 2000
Kawasaki Voyager XII - 1995 - Location: Brasil
Good Tony, tonight I check this
Kawasaki Ninja ZX-12R - 2000
- Has liked: 107 times
- Been liked: 278 times
There is also a 3 Amp fuse in the main fuse panel labelled "Audio". The amplifier, behind the RH fairing, has a 7.5 Amp fuse on the back side as well.
- jek7galo
I dont remeber that have fuse audio at the fuse panel
- jek7galo
Holla amigos,
Was not the fuses and i dont know that was, but I took the opportunity to change the chain of the cassette and the radio comeback turn on.
see the MP3 adapter for cassette that I found
- suzib6sw
jek7galo wrote:Holla amigos,
You will find that the White/Yellow Power cable to the radio has a break in it close to the fuse hold and supressor.. Its very common.. It might not show up for a while but it will re-occur..
The other possibility which is just as common, is the ends of the fuse tarnish inside the fuse holders.. Clean them up and that will remove that problem.
Check out my mods in the link in my signature..
Pete
Pete
