Carb Leak
JTC1
Current bike(s): 92 Kawasaki Voyager
Carb Leak
Post by JTC1 »
Got the bike out the other day to clean it up and had a leak at the first carb on the left side (as you sit on it). Can't see where it is coming from. Anyone go through this before? Do I just need to take it in and have them rebuilt? :gmad:
Jeff and Janet Corbin
Corbin Farm, Dover, PA.
1992 Voyager XII
joemaniaci
Current bike(s): 1989 Voyager, 2004 Honda Interceptor
Re: Carb Leak
Post by joemaniaci »
JTC1 wrote:Got the bike out the other day to clean it up and had a leak at the first carb on the left side (as you sit on it). Can't see where it is coming from. Anyone go through this before? Do I just need to take it in and have them rebuilt? :gmad:
Mine sat for 10 years before I bought it and got it up and running. Noticed after a trip to California that 1 and 3 were leaking at the float bowls. Swapped out all the gaskets just in case.
Has liked: 852 times
Re: Carb Leak
You might try running some Seafoam through it to possibly clean dirt out of the float valves.It does not take much dirt in a float valve to make it flood a carburetor. :corn:
bob1665
Current bike(s): 1987 voyageur
Re: Carb Leak
Post by bob1665 »
I am also having the same problem tried draining and flushing the float bowls and will try the sea foam next before I tear it down. It just started after about 900 miles this spring so I suspect a couple of the floats are sticking.
bob1665
Re: Carb Leak
Post by bob1665 »
Sea foam did the trick put in 250ml to a full tank and ran it for about 10 miles and let it cool off started and ran it again no leaks. Probably go thru the carbs this winter as precautionary. I have had very good luck with this stuff in the past and use it in lots of different applications. :woohoo:
JTC1
Re: Carb Leak
Post by JTC1 »
Has non alcohol fuel with Seafoam in it.
1992 Voyager XII
bob1665
Re: Carb Leak
Post by bob1665 »
Well I guess the seafoam was not a fix after all I ended up pulling the carbs and replacing all the float bowl to carb body o rings and that looked after it. Thanks for all the great info on here to get them in and out its no small task but learned lots about the rest of the internals along the way.
