help quick sensor on top of carbs
- Gator Mike
2002 Honda 750 ACE
Re: help quick sensor on top of carbs
Suspect the plug you are speaking of is for kicking off the cruise control if you manually close the throttle. I believe the other end comes from a harness that runs on the left side of the bike under the faux tank. If it is that plug and it is disconnected the cruise control will not engage. I had a problem with the carb side of the plug so I jumped the two pins on the mating plug to get my cruise to work.
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
