help quick sensor on top of carbs
rwdking
Current bike(s): 1992 Kawasaki voyager xii
Post by rwdking »
Where does it plug in and what does it do
Gator Mike
2002 Honda 750 ACE
1969 Honda 90
Re: help quick sensor on top of carbs
Post by Gator Mike »
Suspect the plug you are speaking of is for kicking off the cruise control if you manually close the throttle. I believe the other end comes from a harness that runs on the left side of the bike under the faux tank. If it is that plug and it is disconnected the cruise control will not engage. I had a problem with the carb side of the plug so I jumped the two pins on the mating plug to get my cruise to work.
1994 Voyager XII
2001 Honda Ace
1969 Honda CM91
Louisiana Patriot Guard Rider
rwdking
Post by rwdking »
Got it found thanks
