gross vehicle weight rating
- Current bike(s): 1986 kawasaki voyager xii
Does someone know the gvwr of the voyager xii with e'3 tires on , thnx
Voyager xxii
Looking forward to meeting new friends
- Tonyvdb
Re: gross vehicle weight rating
It's 800lbs dry so with oil, coolant and gas around 900
- Lucasind
- Has liked: 194 times
- Been liked: 69 times
found these specs : http://www.bikez.com/motorcycles/kawasa ... i_1998.php" onclick="window.open(this.href);return false;
- hank43
- Been liked: 4 times
Lucasind wrote:found these specs : http://www.bikez.com/motorcycles/kawasa ... i_1998.php" onclick="window.open(this.href);return false;
1196.00 ccm (72.98 cubic inches)
Engine type: In-line four, four-stroke
Power: 97.00 HP (70.8 kW)) @ 7000 RPM
Torque: 11.00 Nm (1.1 kgf-m or 8.1 ft.lbs) @ 5000 RPM
Now THAT would make a nice trike!
- Has liked: 854 times
That shows only 8.1 ft lbs of torque??? I think that may be a misprint,as my Cushman makes that much. Probably more like 81.Having ridden both,I know the VXII has considerably more than the Cushman.hank43 wrote:Lucasind wrote:found these specs : http://www.bikez.com/motorcycles/kawasa ... i_1998.php" onclick="window.open(this.href);return false;
- Highway Rider
- Webmaster
- Been liked: 39 times
Well for what it's worth you can pull the large side cover off the left side and it will tell you what the max load capacity is and for the rear tire at 45 psi tire inflation it can handle 445 lb and the front tire can handle 445 lb at 31 psi tire inflation.
I'm not sure if this is additional carrying weight in addition to the wet weight of the motorcycle which is right around 795 lb's. So it is either 795 + 900 for a total of 1700 lb's which is pretty high or it is 900 lb's total weight which is pretty low . I don't know any one who owns one of these bikes and weighs 105 lbs's. I hope some one else will weigh in on this with there opinion on what they think.
That's parked torque. Everybody knows that's rated in wrenches....cushman eagle wrote:That shows only 8.1 ft lbs of torque??? I think that may be a misprint,as my Cushman makes that much. Probably more like 81.Having ridden both,I know the VXII has considerably more than the Cushman.hank43 wrote:Lucasind wrote:found these specs : http://www.bikez.com/motorcycles/kawasa ... i_1998.php" onclick="window.open(this.href);return false;
- chevyman1
- Been liked: 16 times
here is a link to Dunlop E3 tire specs.
http://www.dunlopmotorcycle.com/tire-ca ... te-3-bias/
- Neal
But that would only work if you'd left the pieces of crap Dunlop 404's installed.....There is no way anyone should bother checking for the mfg's suggestions.Highway Rider wrote:Well for what it's worth you can pull the large side cover off the left side and it will tell you what the max load capacity is and for the rear tire at 45 psi tire inflation it can handle 445 lb and the front tire can handle 445 lb at 31 psi tire inflation.
I just looked at my E-3s,the front is rated at 805lbs ,the rear at 908lbs.I found in the operators manual on page 12,the empty weight is listed at 728lbs,and on page 26 the cargo weight is listed at 445lbs,which would add up to 1173lbs GVWR.The specs on the E-3s show they would easily take the requirements of 1173lbs.
Thanks for all of the replys guys , I'm guessing there is no definit answer.
Voyager xxii
- duckman
2019 Voyager
2017 Triumph Trophy - Location: Pensacola, Florida
I've wanted to look this up also because of an article from consumer news so I knew how much weight I can carry. I'm not at home to search the vehicle for markings or check the manual but good numbers are provided here. If the dry weight is 728 and wet weight is 800 then add in the 445 cargo capacity to get the apx total of 1245lbs GVWR. ok fine. I wanted to know the cargo anyway.
I happen to check luggage weight from a trip and it was 100 lbs. I've never had any issues but with luggage and 2 people I was around 525 lbs. Oh boy, over the limit. I don't know anyone personally that has had tire issues or suspension bottomed out causing accidents because of over weight. I do believe that everyone hauling 2 people for vacation is always overweight (including myself). But day rides without luggage will be fine.
So I have learned that I need to go on vacation by myself so I have plenty of weight allowance to bring back trinkets or 2 of us go and all our items must fit the size of a small tank bag. Lets stick with option 1 (right that will go over well)
Wait'in for my ride!
