Starter switch issue
Pbpd183
Post by Pbpd183 »
When my bike sits, it seems the starter switch does not want to engage. It will take numerous, around 3-5 tries to get the starter to kick on. Only happens when the bike sits for 3 days or so. After the first start, no problems. It will start with just a tap of the button. Battery voltage is strong. Clutch is pulled in while on its center stand with the side stand up.
Do the starter switches go bad?
Can I remove it and clean it?
Does anyone else have or had this problem?
Dan
Palm Bay, Florida
Previous
2000 Voyager 1209
doug of so fla
Current bike(s): 07 gold wing
Re: Starter switch issue
Post by doug of so fla »
Dan you live in a SALTY area lol!! Think "CORROSION" First thing to do is go over all your switches with a good spray contact cleaner. Plastic safe one!! clutch switch, kickstand switch, brake switches, and starter switch, and kill switch, and maybe if you find the bad one or ones, clean them up or replace and the most important ones are the battery terminals and starter solenoid connections. also all the wire end connections to all of the above switches. FLA salt air and sunshine ain't free!!!
