Possible Clutch Issue??? PLEASE HELP
- Current bike(s): 2002 Voyager 1200
Hello all, I have a 02 Voyager that has been sitting for the past year, Starts great but when I put it in gear it bogs down and rear tire is barely move. With engine off and on center stand I put it in gear hold the clutch and can barely move the wheel. Any ideas???
Thanks,
Bert
Thanks,
Bert
- Highway Rider
- Webmaster
- Been liked: 39 times
Re: Possible Clutch Issue??? PLEASE HELP
Rear brake locked up? Just wondering. Put it on center stand put in natural and see how hard the rear wheel turns by hand.
Highway Rider thanks, but it spins free in neutral. I've rebuilt slave cylinder, flushed fluid and think no air bubbles in system and checked clutch plates and none were stuck together or burnt.
Thanks,
Bert
Thanks,
Bert
- Tonyvdb
Could it be the final drive? has the oil been changed in it recently?
checked final drive oil level but did not change. Oil level good!
- Avidrider62
- Current bike(s): Bikeless
Bike sit for some time? Carbs could be messed up, when placing torque on engine. So if you let the clutch out at an idle, up on center stand, it bogs down?
2003 with 87 colors
- Avidrider62
Also, a good clutch, you'd feel it in the handle when you pull, like a umph, 1/2 way pulled.
2003 with 87 colors
Avidrider62, thanks, just removed carbs, cleaned and replaced all float needle valves, adjust floats to 18mm. did not sync carbs. Idles fine and revs good. Boggs down and kills engine when clutch is released.
- Avidrider62
So it bogs/kills engine at an idle, up on the stand. Bad clutch won't engage, it'll mainly grind gears or 'clunk". Something in the carbs is aray I'm thinking. I've experienced this myself, finding floats not quite right. Pilot jets ect.. Engaging the engine, even at an idle, puts a load on the engine. 18mm? I know some do this, but Carl and Steve do 17mm. Hooks on the float seats, using OEM design I hope.
2003 with 87 colors
- Tom(North Alabama)
- Current bike(s): 2002 Voyager II
2002 BMW k1200LTE - sold - Location: Madison, Alabama
Bogs down, then engine dies... sounds more like the kickstand switch
'02 Voyager XII
'08 Concours 14 - sold
'02 BMW K1200LTE
'02 BMW K1200LTE
- Avidrider62
Good choice Tom, bad switch or wires came off.
2003 with 87 colors
Yes oem parts. But with engine off,1st gear clutch lever pulled I can just barely move rear wheel. ???
- Avidrider62
engine off, clutch in, tire won't move easily, that's normal
2003 with 87 colors
Tom thanks, I'm at work now but will check kickstand switch in the morning when I get home. The kickstand is currently down and bike is on center stand, so should kickstand be in up position?
Thanks everyone for all your help!
Bert
Bert
- Avidrider62
- Bill O
2003 1200 Voyager
- Been liked: 6 times
MSBert wrote:Tom thanks, I'm at work now but will check kickstand switch in the morning when I get home. The kickstand is currently down and bike is on center stand, so should kickstand be in up position?
Bert
The Voyager has many safety features. One being the side stand switch. If the side stand is down, and it is put in gear, as soon as you try to release the clutch lever, the engine will die. This is normal. After a while the bike will make you look silly. I don't know how many times I've tried too take off with the side stand still down. Always have to look around to see if anyone saw me........
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
1994 Voyager
2003 Voyager
That still happens to me...
- Current bike(s): 1989 Voyager, 2004 Honda Interceptor
If it was one of the safety switch, that wouldn't explain why it bogs down before it dies. It should just die instantly.
kickstand it was. All's good now.
Thanks again everyone for your help!!!!
Bert
Bert
