I currently do not have a headset connection. I am needing assistance in how to set the headset wires up and what I need. Where can I get the connector for the plug behind the headlight and what does it look like?
I have the headset y cable and the headsets. What else do I need.
Thanks in advance
Connecting headset plug
- Bill O
2003 1200 Voyager
- Been liked: 6 times
Re: Connecting headset plug
Mart656 wrote:I currently do not have a headset connection. I am needing assistance in how to set the headset wires up and what I need. Where can I get the connector for the plug behind the headlight and what does it look like?
Thanks in advance
You state you have the Y-cable and headsets. That is all you need. The Y-cable connects to the connector behind the radio (There are two, one for the y-cable and the other input for the CB option). Once the y-cable is plugged in, you route the short connector for the rider location, and the long end is for the passenger. To these connectors you plug in the cable from the headsets. To enable the headset function, you press the "HS" button on the front of the radio. Wether if HS is on or off, the intercomm will be heard over the headsets. HS to on will route all audio (radio, CB) to the headsets.
There is a PDF file somewhere via this site that covers the operation of all the audio functions.
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
1994 Voyager
2003 Voyager
- chevyman1
- Been liked: 16 times
Here is the link for the y-cable installation
http://www.amervoyassoc.org/Documents/YCordInstall.pdf
- Current bike(s): 2002 voyager (sold)
1999 voyager - Location: Wichita Falls
Thank you gentlemen. I appreciate it. I even get pictures, that's great because I am a visual person. I know have a project for tomorrow.
