shift sequence backwards
jlukas4165
Current bike(s): 1987 Kawasaki Voyager 1200
1989 Kawasaki Voyager 1200
1987 Honda 1100 VT
1981 Honda Goldwing GL1100
Post by jlukas4165 »
Thanks to all who helped on my gas leak! After stripping it all apart and wondered if I will ever get it back together again...we have success!!!!
Here's my problem, the gear pattern is upside down??? 1 is up and the rest are down. Is there an easy fix our am I pulling the gear case and fumbling around.
Bill O
2003 1200 Voyager
Been liked: 6 times
Re: shift sequence backwards
Post by Bill O »
jlukas4165 wrote:Thanks to all who helped on my gas leak! After stripping it all apart and wondered if I will ever get it back together again...we have success!!!!
Does your bike have the driver floorboards and heel-toe shifter. If so, the Driver floorboards were incorrectly installed. The Installation instructions are posted in the Tech Section.
Bill O
1994 Voyager
2003 Voyager
2003 Voyager TriKing Trike
Nevada Patriot Guard Rider
jlukas4165
1987 Honda 1100 VT
No the bike does not have driver floorboard, it also has the plain toe shifter, not heal toe.
This was a barn find with 18k miles, so I'm unaware of any history. Other than the reverse shifting pattern the bike runs great
Lance McCaw
Post by Lance McCaw »
The linkage bars are on wrong under the peg.
Lucasind
and a bunch of parts !
Has liked: 194 times
Been liked: 69 times
Post by Lucasind »
The shift shaft must rotate in a counter clockwise direction going into first gear on a normal XII.
doug of so fla
Current bike(s): 07 gold wing
Post by doug of so fla »
Someone could post a photo of the correct shift linkage position on the XII. That would help him out..
chevyman1
Been liked: 16 times
Post by chevyman1 »
The arm on the transmission is wrong it should be pointing in a upward direction.
:thmup:
Click on the link in my signature for the service manuals.
jlukas4165
1987 Honda 1100 VT
Thanks, but the arm is up. Everything appears as it should. Without allot to go by, it appears I may have to open it up thinking maybe someone before me did not set the the neutral positioning lever correctly or gear positioning lever. Hoping it might have been something simple
Has liked: 106 times
Been liked: 275 times
both arms need to be up as shown in the link below. If the footpeg arm is upside down, one would have to lift up for 1st gear.
http://www.abbikeboard.com/forum/viewto ... water+pump" onclick="window.open(this.href);return false;
