I had rebuilt my 1984 Voyager last summer, got top end work done, replaced broken water pump gear, had new parts installed, etc.
Last spring, water pump seal broke, coolant leaking all over. I thought it was cylinder gasket leak...didn't read the manual!...rebuilt engine again before I found out it was the drain hole in the water pump that was pouring out coolant (faces the cylinder/block interface).. Replaced pump seal with new one from BikeBandit.
So, I was on the road again, great rides, until yet again, coolant leaking out of that *&^&$#%$ drain hole.
Has anyone else had this problem, better yet, does anyone have a solution? Pretty sure I'm going to keep having the same problem till I drive the bike off a cliff.
![disgusted scream :gmad:](./images/smilies/goingmad.gif)
