Galfer Braided Brake Lines
- ghostler
- Has liked: 2 times
- Been liked: 10 times
Hello all. Now completing my Galfer braided brake line installation and overhaul of all front brake cylinders on my 2001 XII. I got the lines from Amazon:
http://www.amazon.com/gp/product/B00OBPJEUC for $89 US and free shipping. It says for 1987 to 1993, but I saw no reason not to use on my 2001 and it fits.
Harbor Freight Snap Ring Pliers #60531 for $4 made disassembly of the master cylinder easy.
http://www.harborfreight.com/snap-ring- ... 60531.html
Note, using an awl, I rotated the snap ring toward the brake handle cutout notch for more clearance so pliers could fit. Using the smallest jaw pins and a good light source for visibility, after working the pins into the snap ring holes, it was out in a jiffy. Tool is light duty and if I were doing this for a living, would opt for the best, but for the home mechanic, it is a God send.
I removed the old brake line in its entirety including the hose splitter. Wrapping the lines with high voltage electrical tape for cushion and protection, I used universal strap and short bolts to hold lines to bottom of triple tree.
These new lines are neat in that they provide direct fluid straight from the master cylinder. Also, they have a lifetime warranty. Kawasaki owner manual states to replace brake lines every 4 years and overhaul the master cylinder and calipers every 2 years. I don't know who all do that in reality.
- Attachments
George Hostler
Clovis, NM, US
http://tsammcentral.org/
1971 Honda CB100
Clovis, NM, US
1971 Honda CB100
Re: Galfer Braided Brake Lines
Looks good! I need to do that to my bike. I still have the originals on it and it is 14 years old now. Did they have the rear line available as well?
- Tonyvdb
Does this also improve the breaking power on the bike?
- Current bike(s): 2003 1200
Nor Cal Voyagers have steel brake lines for the Voyager at the bottom of this page
http://www.amervoyassoc.org/index.php" onclick="window.open(this.href);return false;
- ghostler
Yes, here:Mr Jensee wrote:Looks good! I need to do that to my bike. I still have the originals on it and it is 14 years old now. Did they have the rear line available as well?
http://www.amazon.com/gp/product/B00NH6W9PS
Kawasaki 1987-1993 ZG1200 Voyager XII Galfer Rear Stainless Steel Braided Brake Line Kit, $50 and free shipping.
Braided steel lines don't flex like the rubber ones, so braking is more positive. I've bled the lines the manual hard way (pumping master cylinder, hold, release bleed cock, tighten cock, check master level & top, repeat umteen times. Still got an air bubble somewhere, so I'll re-bleed with my HF pneumatic bleed kit (1st time use).Tonyvdb wrote:Does this also improve the breaking power on the bike?
I took a 1.5" long piece of 5/16" auto fuel line, split it lengthwise, used 2 nylon wire ties to hold in place at the mount above the caliper. Still rethinking the lower triple tree mount and chafe protection at the handle bar.
I've run out of time tonight, so will resume soon.
George Hostler
Clovis, NM, US
1971 Honda CB100
Clovis, NM, US
1971 Honda CB100
- chicagorandy
- Has liked: 9 times
- Been liked: 14 times
Us '86 owners will just have to wait I guess.
I asked on Amazon if they will work on mine and was told no. Odd since the bikes share the same parts for MC and brake lines?
- ghostler
I wasn't aware of this option. Reason why I went this route was due to cost. I gathered they were clearing out old stock.voyager55 wrote:Nor Cal Voyagers have steel brake lines for the Voyager at the bottom of this page http://www.amervoyassoc.org/index.php" onclick="window.open(this.href);return false;
Ron Ayers doesn't have 1986 XII listed, so I went to Bike Bandit.chicagorandy wrote:Us '86 owners will just have to wait I guess. I asked on Amazon if they will work on mine and was told no. Odd since the bikes share the same parts for MC and brake lines?
For the top hose:
1986 Fiche #43059: HOSE-BRAKE,FR, Bike Bandit #819368, $78.64
2001 Fiche #43059: HOSE-BRAKE,FR, Bike Bandit #820530, $86.93
Bottom hoses:
1986 Fiche #43059A: HOSE-BRAKE,FR, Bike Bandit #819392, $78.64
2001 Fiche #43059A: HOSE-BRAKE,FR, Bike Bandit #820531, $86.93
Bike Bandit uses their own numbering system instead of OEM, but it shows as 2 different parts. I don't know if in fact they are the same or not. There are differences in the fork and strut assemblies between the 1987 and other years. I don't know if there may be differences in lengths, which might affect hose lengths or other ergonomics (fitting bends, different sized banjo fitting, etc.).
Post edit 17 Sep, 07:59am: Just wanted to add that if one were to attempt purchasing OEM hose parts, Nor Cal would be a good way to go, as one would have already spent $237 just for the front hoses and the braided steel have a life time warranty versus the implied 4 years (see owners manual - servicing) for the OEM rubber ones.voyager55 wrote:Nor Cal Voyagers have steel brake lines for the Voyager at the bottom of this page http://www.amervoyassoc.org/index.php" onclick="window.open(this.href);return false;
George Hostler
Clovis, NM, US
1971 Honda CB100
Clovis, NM, US
1971 Honda CB100
- chicagorandy
I compared parts using Partzilla.com - they use the same hose numbers for both years 86 and 87.
- chevyman1
- Been liked: 16 times
A lot of times there's a air bubble gets trapped in the banjo fitting's and they can be hard to get out.ghostler wrote:Yes, here:Mr Jensee wrote:Looks good! I need to do that to my bike. I still have the originals on it and it is 14 years old now. Did they have the rear line available as well?
- ghostler
For me, it was mind over matter. If I didn't mind, it didn't matter. I didn't contact them, just did my research for my 2001 similar to you and ordered it. It is up to you. I don't know enough to say whether purchase is a safe bet for you or not.chicagorandy wrote:I compared parts using Partzilla.com - they use the same hose numbers for both years 86 and 87.
Thanks, I'm giving the HF bleeder a shot, see if I get that last bubble out.chevyman1 wrote:A lot of times there's a air bubble gets trapped in the banjo fitting's and they can be hard to get out.ghostler wrote:I've bled the lines the manual hard way (pumping master cylinder, hold, release bleed cock, tighten cock, check master level & top, repeat umteen times. Still got an air bubble somewhere, so I'll re-bleed with my HF pneumatic bleed kit (1st time use).
George Hostler
Clovis, NM, US
1971 Honda CB100
Clovis, NM, US
1971 Honda CB100
