bikes
wsm 1
Current bike(s): 1998 gl 1500 SE 2002 voyager xii
bikes
Post by wsm 1 »
I have found two 2002 voyagers that I like ,being new to yhe 1200 can you tell something about that year bike? :help:
doug of so fla
Current bike(s): 07 gold wing
Re: bikes
Post by doug of so fla »
The only problem I remember with the 02's were some had early u-joint failures. Some 02's had some problems as it was said that the tooling was getting old but was nothing radical no recalls that I remember.
Otherwise they had all the upgrades from earlier years in engineering. 88 to 2003 were outwardly basically the same but they did make some engineering changes though out the production years.
I had a 02 and it was perfect for 120,000mi.
What is the mileage and are maint records available.
Maint thru the years is more important than anything else!!!.Good luck and Ride Safe.
wsm 1
Re: bikes
Post by wsm 1 »
One bike has a little over 25,000 miles and the other 35,000.Both bikes are second owners and look really clean in pictures.
doug of so fla
Re: bikes
Mileage looks good if legit?? Be able to examine the XII, pictures do nothing!!. Lots of scammers out there.
Check tires for tread depth cracks & date stamp,
check brake pads,
suspension action, front & rear, Check controls movement, lights.
Make sure every button works.
Look for rust in the gas tank,
Look for any visible corrosion. ect, ect, ect,
& as you have already done the smartest thing, is ASK questions, there are plenty of very knowledgeable owners on this board that will gladly help you along.. Good luck..
