change antifreeze
wsm 1
Current bike(s): 1998 gl 1500 SE 2002 voyager xii
change antifreeze
Post by wsm 1 »
Where is drain plug to drain antifreeze and what is the way you guys go about it?Going to use 50/50 mix. Thanks :help:
Re: change antifreeze
Service manual is on the ava website
I use Peak 50/50
Many use Prestone 50/50
It's been four years since I changed my fluid but if I remember the drain is between the radiator and the engine on a return hose. I think, don't hold me to it. Mine is getting changed as soon as the weather starts to cool.
Carl I just changed my antifreeze which was actually 4 years old and I can tell you the 6mm bolt is on the bottom of a piece of metal piping coming from the radiator and just behind the radiator. In order for it to drain you have to remove the radiator cap. Don't forget to pull the overflow reservoir as well and drain it before refilling with fluid. It should take almost a full gallon of 50/50 mixed antifreeze.
Has liked: 107 times
Been liked: 278 times
Yes indeed, the drain is a 6mm bolt with a 10mm hex head located on the bottom of the steel coolant pipe which runs from the cylinder block manifold pipe down to the water pump. It is the inner of the 2 pipes.
wsm 1
Post by wsm 1 »
Thanks guys ,I got it changed Thursday.Lot of good knowledge on this site and people also. :clap:
