After market parts
George1062
After market parts
Post by George1062 »
I have a unique issue. I just purchased a 1995 Voyager 1200 ( love it), but Im 6'7 with a size 13 shoe. The issues I'm having is with the double seat I sit a bit forward which, when putting my feet up and down, takes a little maneuvering. I am looking for a replacement foot rest and shift/brake arm assembly that would allow for about 1/2 inch in length and 1/2 inch more on the pad and knob, to comfortably get my foot under the shift or on the brake.
I have tried searching ebay and other sites but run into two issues, 1) I get hits back for 1500 Vulcan or 2) OME only.
any one have some suggestion short of having the parts custom machined ?
Then other option I'm considering is replacing the passengers seat with a smaller seat, and changing the main to one that is slightly longer and does not have the back rest.
Thank you
Re: After market parts
This is probably going to require special fabrication to achieve. The shift lever can be removed and raised some for a big foot but as for the brake lever you are out of luck.
