rocker arms has falled out
jek7galo
Current bike(s): Kawasaki ZX-12R - 2000
Kawasaki Voyager XII - 1995
Post by jek7galo »
Friends, I back.
Because my bike fall (one _______(edit by webmaster) hit my fender :tho: ) I lifted her and turn on the engine, when one boy that looking the bike, tell me that have fall something.
Leave the engine on and go see what happened, to my surprise saw the rocker arm on the ground and one hole in the head cylinder valve.. At the same time, turn off the engine and brought it home on the winch truck .
Does anyone know what can be happened to the rocker arm have fall?
I know that him working float, but he is not fixed on inside the head cylinder valve?
:please:
I think that I have the great problem :hmm:
thanks :thmup:
Kawasaki Ninja ZX-12R - 2000
Has liked: 107 times
Been liked: 278 times
Re: rocker arms has falled out
Does the part look like one of these?
http://www.partzilla.com/parts/search/K ... parts.html
If so, then yes you have a BIG problem.
The engine will have to be removed and disassembled.
If not, look at the other diagrams of Partzilla.com to see if you can identify what the part is.
jek7galo
Post by jek7galo »
Hello Dave, Yes, herself, I know that I have the big problem, but don't understand how to fell. we call here "Hydraulic Shock" when a malfunction of the engine, Fills the gas cylinder and does not burn, that consequently push the valve until it left the rocker arm.
Someone has some head cylinder valve for sale?
right saddlebag;
breack ligth
cover fender whith brack ligth
turn signal also?
Please refrain from swearing when you post.
jek7galo wrote:Friends, I back.
:please:
thanks :thmup:
Perhaps you will find what you need here.
http://www.ebay.com/sch/Cylinder-Heads- ... aki+zg1200
jek7galo
Post by jek7galo »
Thankyou Triton;
Excuse me Webmaster;
Friends, but I dont understand how a bike fall made the part get out? :hmm:
Me Again
Been liked: 262 times
Post by Me Again »
After reading the original post a couple of times I suspect the word "fall" is a translation error and should be "failed".
It also sounds a little bit like he just plain blew the engine .
That's the only way I can see a rocker outside the engine .But then again it may be in my translation ,
He did say it "fell" and hit the fender
Any resemblance to swearing is probably also translation errors .
Highway Rider
1978 KZ650 D1 SR
Has liked: 138 times
Been liked: 39 times
Post by Highway Rider »
Say jek7galo do you have a way to post a picture of the issue that would be vary helpful
jek7galo
Post by jek7galo »
I have problema with my translator :bat:
here is the link of image: http://prnt.sc/e8ab6m
After the bike fall down, when starting the engine, this happened.
Highway Rider
1978 KZ650 D1 SR
From the screen capture that you posted it looks like the head is broken and you could get a replacement head. I saw one on EBAY for around $200.00 USD. and the I would imagine that you are going to have to pull the motor the change it. If that is the case you might be better off seeing inf you could locate a used motor and putting it in less work to accomplish the same thing. I'm sure you should be able to locate a motor with less then 100,00 miles on it.I would not hesitate to put one in with those miles on it as these motors are good up to 300,00 miles or more if take care of properly. Just some food for thought
jek7galo
Post by jek7galo »
I saw on ebay some cylinder head but I am speaking with forum member that have one to I buy. One engine I believe that no easy send to me, because of the taxes of the Brazil, but I go try.
