Light Bar
sgilbert14
Current bike(s): 1998 Concours 1000
Just purchased a 2000 Kawasaki ZG1200 Voyager XII for the spring
Light Bar
Post by sgilbert14 »
I have a set of Denalli D2's that I want to install and have been seeing a light bar installed on some bikes just below the head light. Is this available somewhere ?
So much on the "want list" when you get a new bike.....
Re: Light Bar
The light bars I have seen mounted under the headlight of Voyagers were made by the owners. As far as I know there is no manufactured light bars. I mounted mine on the crash bars which provides a very noticeable triangle of light that cars can see for a long way off. Just sayin.
sgilbert14
Re: Light Bar
Thanks, that was where I was thinking of putting them.
Been liked: 82 times
Re: Light Bar
They did make a light bar. It sat between both ends of the front crash bars. Which also help to stiffen the front crash bars. You'll have buy or build a center section to tie both of the front crash bars. Check with the mid Atlantic Voyagers they have two members that make after market bits for the voyager. Also call Carol Leo he should be able to help.
Re: Light Bar
Don the bar you are talking about is still being made and sold. I have seen them new on Ebay and elsewhere but I cannot remember where.
Re: Light Bar
I found an old post that might be of use to you.
viewtopic.php?f=3&t=8418&p=63854&hilit=light+bar#p63854
I mounted a pair of Nighlights I got off Amazon.com for about $30 shipped. They are small, extremely bright and being square they seem to match the squarish styling of the bike. They also don't draw any more than 3 amps so they don't stress the alternator.
[video]https://www.youtube.com/watch?v=jE-CeRtAtzM[/video]
sgilbert14
Re: Light Bar
I like them mounted there. I actually have one of them lights mounted on my snowblower. I have the D2's but I think I have my mounting location.. Thanks
davidl
Re: Light Bar
Post by davidl »
I have these on my XII and they are bright! Almost the best money I have spent. Best money was the headlight modulator.
Re: Light Bar
Kaw used to make a light bar, I bought one
Re: Light Bar
Head light modulators should be standard equipment. A must :thmup:
davidl wrote:I have these on my XII and they are bright! Almost the best money I have spent. Best money was the headlight modulator.
davidl
Re: Light Bar
Post by davidl »
I agree. It has saved me more than once. People just don't see motorcycles.
sgilbert14
Re: Light Bar
Thanks, lights are something that I always add for safety. So, the modulator sounds good.
HarryL
Re: Light Bar
Post by HarryL »
There is a bar for sale in our classified section for $65 that goes between the crashbars.
sgilbert14
Re: Light Bar
Thanks, I saw that and had no clue what it is for or how it would mount.
Re: Light Bar
It's not the Kaw bar, but you can mount lights on it. It goes inside each end of the crash bar. Simple to do
geo1062
Current bike(s): 1995 ZG 1200 Voyager XII
Re: Light Bar
Post by geo1062 »
I had put driving lights on under my head light plenty of room and easy access to wiring, while they did help with visibility, as the weather changed so did the pressure in my front shocks, first turn into a parking space at the store , snapped both lights right off. I would suggest mounting them elsewhere.
Draxxis
Re: Light Bar
Post by Draxxis »
I have a pair of Cree LED fog lights installed on my bike. I have them installed on the highway bars on my bike. That way They are always in the correct position and I don't have to worry about nose dive on the bike.
I like the look of lights mounted just below the headlight, but where I have mine are more practical and just as easy to wire up.
sgilbert14
Re: Light Bar
Thanks, I like the highway bar mounting so I think that is where I will be mounting them.
I see that the highway bar has a flex to it so I image that the bar for sale is to stiffen them up? If that is still for sale once I do a few other things to the bike I may pick it up for the bike.
Been liked: 235 times
Re: Light Bar
I went the economical (read, "Cheap!") way, and bought a piece of galvanized steel water pipe, of the proper OD, inserted it between the crash bars, drilled all the way through both pipes, in place, and added a threaded bolt, with a lock-nut, on each side, to secure everything in place. There is at least one topic on this subject which is where I got the info on, "how to". Also mounted some 10W LED's down there. Love 'em!
Bought, and about to install, a 35W LED Headlight bulb, Hi/Lo. Only issue is a modulator for LED's is around $110! My incandescent Modulator is malfunctioning, so it needs to go. Trying to ease the stress on the alternator/battery by reducing Watts drawn. Converted all light to LED's, except the headlight (soon...), and the dash lights.
Good luck with your bike! Cheers! :thmup:
sgilbert14
Re: Light Bar
