Headlight not working after winter storage
shesseltine86
Current bike(s): 1986 Voyager 1200 XII
Post by shesseltine86 »
After getting my bike out of the back of the garage from it's winter slumber, the headlight will not come on. Any ideas on where to look first? I am going to print the schematic and start tracing power. Thanks for any suggestions
Glad to be riding again!
Previous bikes: 01 Harley FXDX
98 Suzuki Bandit 1200
01 Suzuki Bandit 600
85 Suzuki 850
76 Yamaha 360
Re: Headlight not working after winter storage
.. have "we" forgotten that the headlight won't come on 'til you hit the
starter and the charging circuit brings it on???!!!!! Put a voltmeter on
your battery and start the scoot and make sure it's charging..... JM2C
shesseltine86
I found the 15 amp fuse to be blown and a replaced it and the headlight works fine now. I find it strange that it just blew and is OK now. Any thoughts?
85 Suzuki 850
76 Yamaha 360
Phishhead61
Current bike(s): '93 Kawasaki Voyager XII
Post by Phishhead61 »
I had a similar situation. I would suggest pulling the headlight. I found one of the wires had shorted out at the plug. I ran a jumper wire and made it to the ride I was headed to, but after that spliced/soldered in a new socket. No problems for about 6 years now.
Phishhead61
scottolds
2009 Kawasaki KLR650
2011 Ural Gear Up
1987 Honda Super Magna
Post by scottolds »
Mine was blowing headlight fuses and it turned out in the end that it was some very corroded terminals on the 10 pin main connector going to the fuse block.
If nothing else looks suspicious, you might want to look at that connector.
shesseltine86
Awesome, thanks for the info! :thmup:
85 Suzuki 850
76 Yamaha 360
corrosion on the terminals increases resistance and can blow a fuse. I suggest spraying all connectors with electrical contact cleaner and follow up with a dab of dielectric grease to prevent it from happening again.
