40W LED H4 Motorcycle Headlight Bulb Review
Been liked: 238 times
Link to Amazon, where I ordered the bulb from.
Cost: $26.99 (Currently unavailable...)
Color: 6000K (slight bluish tint)
Lumens: 3,000 (Bright!)
Moving Parts: None, uses braided bands of steel(?) as a heat sink, nothing to seize up, no reason for it to overheat, and burn out.
Difficult to install: Not at all! Has a plug which matches the H4 bulb of the bike, perfectly.
Would you recommend/buy another: in a heartbeat, Baby! :LvStrk
Pattern on Street, at Night: identical to the Halogen H4 I pulled out; I swapped the two, back and forth, to compare the beam pattern, then I took it out at night, to verify it was 'normal' in light pattern... It was.
Bottom Line: Buy it, when it is available again! Carry a Halogen back-up, but only as a back-up. Cheers!
Gr8wht
Current bike(s): 2001 Voyager XXII
Re: 40W LED H4 Motorcycle Headlight Bulb Review
Post by Gr8wht »
Appreciate the write up!
Wondering if you have any additional feedback.... has it been trouble-free? An issues?
Also... do you run a modulator on your headlight?
Thanks!
Draxxis
Post by Draxxis »
I have thought of switching to led for the headlight, but I love my 55W HID 6000K light that I have in mine. Super bright and the throw, both forward and off to the sides, is amazing!! Especially for riding the back roads and farming areas where I tend to end up. Plus they are great on the highway for road signs.
No issues yet (fingers crossed...). Will be purchasing an LED-specific Modulator next month. About to haul it to Arkansas on Saturday, where we will drop the bike, and do day trips, before loading it back up, and hauling it back to Minnie-Soda. Hauling will get us there faster, so we can spend more time down South. Did this last Summer, to get to the Cabot Trail, in eastern Canada. It was actually nice pulling the bike, and then driving it upon arrival at our starting point. Wish we had the Modulator on-board, already, but it did not happen. Praying we'll be visible enough, without it. Run two LED's down on the crash bar, to make the train-like, triangle of lights. Cheers!
sheiserman
Been liked: 15 times
Post by sheiserman »
SgtSlag wrote:No issues yet (fingers crossed...). Will be purchasing an LED-specific Modulator next month. About to haul it to Arkansas on Saturday, where we will drop the bike, and do day trips, before loading it back up, and hauling it back to Minnie-Soda. Hauling will get us there faster, so we can spend more time down South. Did this last Summer, to get to the Cabot Trail, in eastern Canada. It was actually nice pulling the bike, and then driving it upon arrival at our starting point. Wish we had the Modulator on-board, already, but it did not happen. Praying we'll be visible enough, without it. Run two LED's down on the crash bar, to make the train-like, triangle of lights. Cheers!
Good call on the Arkansas trip. I think you will be visible enough...I was with stock lighting. The deer seemed smaller, but much quicker. They don't dilly-dally like yankee deer.
Of course I don't know where you plan on riding, but I'll put a plug in for the Talimena run. I liked that better than the Pig Trail. Both were great though. Enjoy the trip.
We're doing day trips out of Bettendorf. Leaving tomorrow...
We both wear hi-vis jackets, have for years. Still, I've repeatedly seen cars begin to creep out in front of us, then stop. My assumption was that the modulated headlight caught their attention. We will see if it still holds true without the modulator.
Thanks for the head's up on the southern deer. Not a fan of yankee deer, at all. Too many close encounters, in car and on the bike. Cheers!
Gr8wht
Post by Gr8wht »
Thanks for the info..... safe travels!
rdvrs49
Current bike(s): 2003 Voyager XII
2000 Vulcan 800b
Post by rdvrs49 »
SgtSlag, Is this the same bulb? Amazon still does not have them available.
http://www.ebay.com/itm/H4-9003-HB2-Hea ... 568ec4b167
Looks to be the same bulb. It's cheap enough. Take a chance. I love mine. :perfect10:
You reminded me: I need to order my LED-compatible, modulator... Not cheap, but worth the investment, based on 10 years of experience with them YMMV. Cheers!
I recently installed the Kisan LED-specific Headlight Modulator. It was plug and play, super-easy to install. This unit is programmable for light sensitivity, and that is one of the features which sold me on it.
After installation, I tested it, of course. I found it's default light sensitivity setting quite good: it turns itself off at dusk, unlike others I've used, which continued modulating until it was well past dusk, and too dark to modulate, for my comfort.
I also noticed that it really modulates between Hi abd Lo beams, due to the headlight failure mechanism in the Voyager. I actually like this. Noticed similar behaviour with the incandescent bulbs, too.
If you are in the Headlight Modulator Camp, I highly recommend the Kisan unit. Cheers! :perfect10:
