Passenger Radio Controls
Aladinbama
Current bike(s): 2000 Kawasaki Voyager XII
1997 Honda ST1100
Post by Aladinbama »
Need some help!
My passenger controls are currently hanging. The PO apparently lost the mount bolt and just kind of zip-tied everything together on the grab bar. I'd like to fix that, but I can't find the passenger controls in any of the schematics I've looked at (found the cover) and therefore don't know the bolt size. Anybody have a clue as to what size that bolt is?
Thank You!
misft
Been liked: 13 times
Re: Passenger Radio Controls
Post by misft »
:hmm: Can't ya ask something easier than that? Anyway, I would try a 6mm X 1.00 thread X 19mm length (approx. 3/4 inches) phillips head screw. I'm thinking that it is supposed to have one of those spacer type washers which is also probably lost so don't over tighten.
Has liked: 107 times
Been liked: 278 times
The illustration you are looking for is shown on the "Chassis electrical equipment" page of the 2000 microfiche.
Aladinbama
1997 Honda ST1100
misft wrote::hmm: Can't ya ask something easier than that? Anyway, I would try a 6mm X 1.00 thread X 19mm length (approx. 3/4 inches) phillips head screw. I'm thinking that it is supposed to have one of those spacer type washers which is also probably lost so don't over tighten.
It's a 6 x 1.0 thread and I found something that will work! I used the 5mm wiggled in and the 8 wasn't even close so it has to be a 6 or 7 method. Went to Lowe's and tried the 5mm I had in the holes and settled on the 6mm. UNFORTUNATELY I picked the 30mm length. Got home and they were too long - dug through my bolt pot and found an old tag bolt that worked. Hopefully we have my issue of the radio cutting on and off solved - I was thinking it was one of the zip ties hitting the wrong spot on the controls and the bouncing of the bike.
Now on to the cruise control :) Thanks Guys!
