Recommended headlight bulb and spark plugs
- Current bike(s): '91 XII
What’s your recommendations for the above?
Stock or have you found better?
- Current bike(s): 2003 1200
Re: Recommended headlight bulb and spark plugs
I use a 55/60 watt headlight bulb.
Spark plugs NGK Iridium- DPR8EIX-9
Info is on the Main site, Dollar for dollar link
I also used the NGK Iridium plugs. On the Bulb a Phillips for Motorcycles.
- Avidrider62
- Current bike(s): Bikeless
I installed Sylvania Ultra Silver Star bulb, wider, brighter, same wattage as stock
2003 with 87 colors
Thank you for the replies!
Do the 80/100 watt H4 bulbs overburden the electrical system?
... read somewhere, oversized bulbs burn everything... wires, sockets, enclosures....
Stick with stock W size, maybe get a whiter bulb? Run some LED running lites
to get more notice?
to get more notice?
If you want to be seen instead of trying for a higher wattage headlight bulb, do what I did and mount a set of high power LED driving lights on the crash bars. YOU WILL be noticed.
+ 1 ... me too and you might some bright lites flipped atcha!!! GBG
Make sure they are adjusted "friendly".....
