Headlight Relay
gscoggan
Current bike(s): 03 Voyager
88 Voyager (parts)
Headlight Relay
Post by gscoggan »
Could someone direct me to the location of the headlight relay, please. My headlight just flashes on for a second when I start up then goes out. No dash lights either. Going to check the 10 wire connector, but am wondering about the relay.
Been liked: 104 times
Re: Headlight Relay
Under the faux tank on left side. Gang of 3. main, starter, and headlight relay.
gscoggan
88 Voyager (parts)
Re: Headlight Relay
Post by gscoggan »
Thank you very much!
Re: Headlight Relay
Have you checked all your fuses? Have you checked to see if the ty wrap that bundles the wires below the ignition key is still there. If it is cut it off.
