Hi Guys -
Just looking for opinions here, regarding what psi you prefer to run your front & rear shocks.
I'm currently running about 40 psi in both. It seems pretty stout, even when both my wife & I (combined weight of about 400 lbs) ride. When I'm alone it's pretty bumpy.
Am I completely out of range here and being stupid?
What's comfortable for you guys?
Preferred Air Shock Pressure
- doug of so fla
Re: Preferred Air Shock Pressure
8.5lbs in front stock shocks ONLY!!!!!! 30 to 45lbs in rear. Shock oil should be changed in both front & rear if stock shocks & unless they have been maintained to the max thru there life they are probably pretty well wore out and a set of Progressives would do it wonders.
