New to Voyager questions
- Current bike(s): 1990 Kawasaki Voyager
Hello
I am excited to be riding again and just bought a 1990 Voyager. I have a couple of questions though.
1 is there a fuel shut off valve.
2 can any recommend mufflers for the bike the last PO put straight pipes on it and it is way to loud. Or is it cheaper to go with used pipes.
3 there is no power what so ever to the radio I have read that there are 2 fuses at the back and on in the fuse box. Which one would be for the overall power.
- Has liked: 228 times
- Been liked: 602 times
Re: New to Voyager questions
Welcome to the asylum.
Some of us have wired a switch to defeat the starter solenoid. This allows filling the float bowls without turning the motor over. If the bike's been sitting for a week or so, this lets it start as if it had been ridden earlier that day.
No. It's an electric pump.1 is there a fuel shut off valve.
I bet cheaper to go used. You might look for Cobra pipes, AFAIK the only real bolt-up alternative. Search here for possibly fitting stock Harley pipes, which are readily available because the Harley crowd almost always puts on pipes that are way too loud.2 can any recommend mufflers for the bike the last PO put straight pipes on it and it is way to loud. Or is it cheaper to go with used pipes.
Can't help you there. Don't need no stinkin' radio. But I've seen lots of threads about the radio.3 there is no power what so ever to the radio I have read that there are 2 fuses at the back and on in the fuse box. Which one would be for the overall power.
- Has liked: 105 times
- Been liked: 273 times
There is also a 7.5 A fuse mounted to the back of the amplifier-----this fuse isn't shown on any schematics.
Thanks for the responses I think I will look into used pipes on eBay. And I will check for that fuse.
- Current bike(s): Kawasaki 1991 Voyager XII
Honda 2016 Africa Twin
Honda 2003 SuperHawk 996
Yamaha 2015 FZ-07
Honda 2009 XRL650
Honda 1982 NightHawk 450
Honda 1971 CB350
Honda 2014 Grom 125
Honda 1971 CT90 - Location: Austin, TX
- Has liked: 2 times
- Been liked: 134 times
Is there any chance to recover the pipes the foolish PO removed from a nice looking machine.
Also check on the facebook voyager XII Page , there are always parts there.Hadyn wrote:Thanks for the responses I think I will look into used pipes on eBay. And I will check for that fuse.
