Oil seal
- Current bike(s): 1986 kawaski Voyager xii 2010 Yamaha r1
Oil seal
Does anyone know what the part number for the shifter shaft oil seal is?? I have done tons of digging and can't confirm the part number to order it. 1986 voyager xii
- Has liked: 228 times
- Been liked: 602 times
Re: Oil seal
There's a parts manual floating around here, probably called "ZG1200_B1-B5_VoyagerXII.pdf". I find it's usually pretty worthless; and I couldn't find what you're looking for this time. So, can't help.
Just saying that if you don't know about it, you might look for it. Occasionally it actually does help.
- Has liked: 105 times
- Been liked: 273 times
Re: Oil seal
If you are referring to the seal fitted into the front bevel gear case then that seal is 92051-005.
