Bevel case
Sparky-29
Current bike(s): 1986 kawaski Voyager xii 2010 Yamaha r1
Bevel case
Post by Sparky-29 »
Has anyone changed the bevel case shift shaft seal. Is it pretty simple. Is there any to do's and to dont's. Any advice would be great
Sparky-29
Re: Bevel case
Post by Sparky-29 »
I've found no information on this. I can't believe none else has had this seal fail yet. I suppose I will start digging In on It
Re: Bevel case
I would consult with Carl Leo on this. He may have some pointers.
Been liked: 82 times
Re: Bevel case
Are you asking about the pinion seal, on the Diff?
Been liked: 134 times
Re: Bevel case
Are you referring to the pinion on the engine ? Make sure it is engine oil...SMELL IT . Gear oil from the rear final drive is known to migrate forward making one think it is the front bevel gear case leaking into the U-joint boot.
Re: Bevel case
... and once you over fill your final drive, it will drip for a LONG time!!!!!!
... don't ask.... sigh
Has liked: 852 times
Re: Bevel case
If you are getting gear oil forward from the final drive,you may have a final gearbox that did not have the vent hole drilled from the factory.You can research that on this forum.My '99 did not have the hole drilled,and it was not until 5 years ago,that I found it out. :hmm:
Without the hole drilled,as the oil warms up and expands,the pressure can overcome the seal and the oil can go forward to the flexible seal and leak out.
Sparky-29
Re: Bevel case
Post by Sparky-29 »
I'm referring to the shift shaft seal. I'm positive its leaking I can lay under it and wiggle the shaft and get a drip to come out. Its engine oil. The bike sat for 5 years In the shop and I think the seal may have dried out a little.
Sparky-29
Re: Bevel case
Post by Sparky-29 »
Also my bike is an 86. I do believe it has the small vent hole on the final drive.
