Replacing oil pan
coffeeboy4
Current bike(s): 1996 voyager XII, turned into a trike by motor trike company
Been liked: 6 times
Replacing oil pan
Post by coffeeboy4 »
Hi everyone, the front drain hole on my oil pan is cracked. What’s all involved in replacing the oil pan.mines a 1996 voyager. :help: Thanks
Has liked: 228 times
Been liked: 602 times
Re: Replacing oil pan
Search is your friend. You'll need to loosen at least one of the headers. While in there, consider replacing the dozen or so o-rings and some gaskets. That stuff has a finite lifetime. Pretty sure this is a pricy part.
Been liked: 134 times
If you are referring to the most forward drain plug. You're in for more bad new's to follow.
coffeeboy4
Been liked: 6 times
What other bad news? :?:
chevyman1
Been liked: 16 times
Post by chevyman1 »
If you need an oil pan I have an extra :thmup:
coffeeboy4
Been liked: 6 times
Hi there, yes it looks like I’m going to need one. The hole is cracked & it runs into the body. I live 30 miles east of Pittsburgh, Pa. Phone # is 724-837-7621. Do you know what gaskets & o-rings I would need?
Look on the manuals available here for the parts you need. I wasn't able to get all from one vendor. The local dealer gave me wrong parts -- go by PNs in the manual. This isn't a big job, but it is a PITA. And I had to wait on o-rings. I assume you should've had a skid plate. But honestly, after sorting my suspension -- Progressives in front and replace oil in shocks -- bottoming like this hasn't been an issue.
coffeeboy4 wrote: Fri Jul 19, 2019 2:11 am What other bad news? :?:
Usually it is the rear plug and filter that take the hit. The front plug is rather far up. Higher than the exh pipes. Did the exh pipes take the hit also ? Do a good inspection of all the damage. As you have seen there are quite a few people that can help out with parts. Hope that you can get what you need to get this going again and there is no damage to the lower case. How did all this happen ? Gene Kap
coffeeboy4
Been liked: 6 times
Gene, it didn’t take a hit, I changed the oil & when I started the bike up it was dripping oil. I checked & thought it was a bad washer on the drain plug. Drained the oil & looked, there was a crack on one side. I must have tightened plug to much.
Has liked: 852 times
coffeeboy4, be careful you do not overtighten the plugs, the drain plug torque is 22' lbs, the filter is 14.5' lbs. I have had to replace my washers a couple of times in the 9+ years I have had my' 99, as they do start to crush.
