Rear Shock and Front Fork Changes
jellyfish5714
4
Current bike(s): 2000 Kawasaki Voyager XII
1996 Kawasaki KLX 650 C
Post by jellyfish5714 »
I have a 2000 Voyager, and am looking to convert the suspension from air to normal. For the rear shocks, I was looking at the Progressive 412 series. If i get the progressive fork spring kit for the front, are there any other changes I need to make to get it working?
Has liked: 228 times
Been liked: 602 times
Re: Rear Shock and Front Fork Changes
Search this site -- much discussion.
Has liked: 100 times
Been liked: 69 times
Post by Barry »
Start here: https://www.amervoyassoc.org/techtipsXII.php
Please note it is possible to install front progressive springs without removing the forks. Lots of discussion elsewhere on this topic. Also with the 412 rear shock, be sure to get heavy duty springs and not the standard ones.
jellyfish5714
4
Barry wrote: Tue May 12, 2020 8:54 pm Start here: https://www.amervoyassoc.org/techtipsXII.php
Thank you for the input, it's good to know I won't have to take the fairings off again to get to the forks. I'll make sure to get the heavy duty springs for the rear shocks as well.
.. like all things, I think if you check the archives, there are many thoughts about
the type of rear shocks... I'm a lightweight and think HD shocks would
NOT be a good idea... JM2C ... do your research..... Best to ya!!!! I've
already put in Progressive front, waiting for the rears to go then will
do them... and I will not put on HD shocks.
Post by Barry »
If you carry a passenger or pull a trailer, the HD is the way to go. I no longer do either, and the HD set on the lighter settings works fine for my 230 lbs. I've not heard any comparison as to whether the standard or HD provides the best ride when solo. If you aren't aggressive in the corners, the standard should work fine.
