I changed my fork oil and seals yesterday. I also added some neoprene fork guards to help keep the seals safer from crispy bugs. Turns out I had progressive springs and tranny fluid. I filled it with 10wt fork oil because I had it on the shelf. It looks like the filter mentioned in the manual is no longer in the forks. Im guessing it gets removed with the progressive springs. Anyway I did the job with help and did NOT remove the fairing. I also noticed I had some fluid in the air line when I removed the valve core. Now im pretty familiar with the fork set up, changing the oil in the future would be easy enough to do with just draining and filling forks in the bike.
https://photos.app.goo.gl/e9WWNKS38LJdswFt6
changing front fork oil
- Bonnie and Clyde
2007 KTM Super Enduro 950
- Been liked: 50 times
Re: changing front fork oil
- These users liked Bonnie and Clyde's post:
- SgtSlag (Wed May 11, 2022 6:28 pm) • Barry (Wed May 11, 2022 7:57 pm)
- Has liked: 500 times
- Been liked: 445 times
Correct, the filter is not used with Progressive springs.
1977 Com-Pac 16 "Hesperus"
Oh, and let us know how your bike rides. I have 10wt in my front forks, and Progressive springs, and it seems too stiff.
- Bonnie and Clyde (Thu May 12, 2022 2:53 pm)
- Has liked: 239 times
- Been liked: 623 times
10wt seems a tad stiff in my shocks, too. Even when fully packed.GrandpaDenny wrote: ↑Thu May 12, 2022 12:49 amI have 10wt in my front forks, and Progressive springs, and it seems too stiff.
Interesting how Kaw specs 10w-20 (no longer available). Maybe the Dexron guys are on to something, or maybe can mix 5w and 10w to come up with 7.5w? I think Don in CA did that in a video, or maybe he mixed 10w & 20w to come up with 15w? I forget - I do remember seeing Don's video, but don't remember the details.Nails wrote: ↑Fri May 13, 2022 2:30 am10wt seems a tad stiff in my shocks, too. Even when fully packed.GrandpaDenny wrote: ↑Thu May 12, 2022 12:49 amI have 10wt in my front forks, and Progressive springs, and it seems too stiff.
Did you they hear came they with up a dyslexia for cure?
Denny,
That was on my rear shocks that I mixed 5w and 10w Amsoil fork oil. In the front forks I use 5w Amsoil. If you have progressive springs, you might have to adjust the amount oil volume in your fork legs. By lowering the oil volume in each fork leg you can soften the front end.
Thanks Don. Interesting that you went heavier than spec on the rear shocks and lighter on the forks.
