front wheel
rustynut51
front wheel
Post by rustynut51 »
i have a new valve stem for front tire . it's the 90 degree . which way does it need to be installed . with the cap facing the engine or facing the front . my now has just the valve stem straight up. thanks
Has liked: 854 times
Re: front wheel
I would install it to the right,or left,which would make it easy to put a gauge on it,or fill it :hmm:
Re: front wheel
.... anybody ever come up with a measurement as to how long the stem and cap can
be without hitting the brakes?????
Me Again
Been liked: 262 times
Re: front wheel
Post by Me Again »
cranky wrote: Tue Apr 26, 2022 1:47 am .... anybody ever come up with a measurement as to how long the stem and cap can
most standard 90s should be fine . just make sure it is pointed opposite of tire direction so you don't snag it and tear it off at 90 MPH
cranky (Wed Apr 27, 2022 2:30 pm)
Van Voyager
Has liked: 46 times
Been liked: 40 times
Re: front wheel
Post by Van Voyager »
Personally, I'd point it to the rider's right so it's marginally easier to get to when on the side stand.
cushman eagle (Tue Apr 26, 2022 10:09 pm) • cranky (Wed Apr 27, 2022 2:30 pm) • Kilarneyinfors (Mon May 02, 2022 8:22 pm)
Rating: 33.33%
sheiserman
Been liked: 15 times
Re: front wheel
Post by sheiserman »
I haven't, but years ago I had the dealer put a 90 deg. stem on. He showed me he had to roll it to the front at roughly 45 deg. to keep it from hitting. Never have had a problem.
Van Voyager wrote: Tue Apr 26, 2022 8:56 pm Personally, I'd point it to the rider's right so it's marginally easier to get to when on the side stand.
Yep. Again, not something I thought of, but the dealer did.
These users liked sheiserman's post:
cushman eagle (Mon May 02, 2022 12:33 am)
Has liked: 228 times
Been liked: 602 times
Re: front wheel
Agreed. For the rear tire, I've found that most shops want to point it away from the brake. But that's a royal PITA to reach under the saddlebag. (As opposed to a garden-variety PITA on the right.)
I'm making do with a straight stem in front.
Has liked: 100 times
Been liked: 69 times
Re: front wheel
Post by Barry »
If you put a 90 degree stem on the front, take the time to rotate the wheel and see how close it comes to the brake caliper. I ended up placing mine at a 45 degree angle to increase clearance. Also think about what would happen should it rotate and snag the caliper. Angle the stem to your comfort level. I never had a problem with it moving.
Chris Cochran
2006 Vulcan 750
Has liked: 61 times
Been liked: 58 times
Re: front wheel
Post by Chris Cochran »
I have a 90 degree brass thing that I attach temporarily when I check the air in my tires, both Voyager and Vulcan.
Van Voyager
Has liked: 46 times
Re: front wheel
Chris Cochran wrote: Tue May 17, 2022 2:34 pm I have a 90 degree brass thing that I attach temporarily when I check the air in my tires, both Voyager and Vulcan.
I tried one of those - it broke on the first air check. I ended up installing a 90 degree valve in the rim (on the rear)
